| Class D Switching Power Amplifiers and Power D/A conversion |
For Class D amplifiers, the linearity of the output filters is paramount with regards to sound quality.
What are the best type of output inductors? Aircore or ferromagnetic? Aircore will not suffer from saturation or core losses, but will have higher resistance for a given inductance and its magnetic field will not be contained. Will the necessary proximity of the inductor to the switching transistors negatively effect the performance of the circuit due to the generated magnetic field? What are the best ferromagnetic materials and winding topologies? What are the best type of output capacitors? It is obviously important that its properties do not vary dramatically with temperature or power. I have also heard of capacitors suffering from the piezoelectric effect, could anybody offer further insight on this? Multilayer ceramic capacitors (ex. those produced by AVX) look very interesting. Thanks, Thadman
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." |
#2 |
INDUCTOR:
air core is a bad idea because of high resistance and high capacitance, not to mention the size. Both gapped ferrites and distributed airgap powders have their pros and cons. Best powders are molybnedium permaloy (MPP) and slightly worse but way cheaper sendust materials (aka. koolmu, super mss, ...). CAPACITOR: basically SMD is a must, good quality film caps are good but rare, ceramic NP0/COG are the best choice, but are hard to find with higher voltage ratings. A bank of smaller value ceramic X7R is often the cheapest and still acceptable solution. |
#3 |
The problem should be divided into two cases (at least): feedback after output filter and feedback before filter (or no feedback). Post-filter feedback makes filter linearity less important, but it needs a good high-freq behaviour.
#4 |
Are any of the SMD inductors suitable? Vishay makes some smps inductors which can handle over 80 amps with very little resistance. They don't appear to be the pinnacle of linearity, but I'm not sure how much of a problem that would be if post filter feedback is used.
#5 |
They are probably drum inductors, which radiate a lot of EMI unless very well shielded.
E cores and toroids behave better. |
#6 | ||
Key parameters are: - saturation current and characteristics (distortion), - HF loss, - capacitance, - stray magnetic field, - DC resistance, - price, - size, - repeatability, - mountability, - etc... |
| class-d output filter indispensable? | motomoto | Class D | 10 | 10th September 2010 07:24 PM |
| Class D output low pass filter EMI suppressor | rickco | Class D | 4 | 28th October 2009 05:15 PM |
| Class D - LC output filter - C ripple current | Skeebopstop | Class D | 8 | 26th February 2009 05:08 AM |
| Shielded or Toroidal Inductors for Class D output filter | speakerguy79 | Class D | 24 | 10th February 2009 10:33 PM |
| smps output filter inductor design | zilog | Power Supplies | 7 | 30th August 2008 11:47 PM |
| Page generated in 0.08864 seconds (75.32% PHP - 24.68% MySQL) with 10 queries |
