hi friends,
Am doing an integrated-circuit design for driving high impedance load like that of a speaker inside a hearing-aid. I am adopting a closed-loop PWM class-D which is of non-self oscillating type. I am currently facing some issues which I am unable to solve myself.
The first is that am finding it difficult to find the appropriate speaker models for that used within a hearing aid. I tried a lot of googling but I am not able to get any. Any help would be greatly appreciated.
thanks in advance,
thanks in advance,
Just buy a complete unit and strip for parts:
DealExtreme: Search for hearing aid (101 products in 30 categories)
The issue of power consumption and distortion in hearing aids is so serious it might only be competitive to design the amplifier for a particular driver design. I imagine the variation in load impedance of commercially available product could be as wild as seen in headphones, except for maybe a more limited supply voltage range.
Just curious: Why are you given the task to develop a class-d amp for a hearing aid and at the same time you will not be provided with the properties of the transducer involved ? Or are you developing a solution that should cover a wide range of transducers ?
Charles
Charles
Try in-ear receivers from:
Star Micronics (used in e.g., Etymotic earphones)
Subminiature Speakers :: Knowles
Sonion
Erik Ostlin
Sonion
Erik Ostlin
- Class D
- class D driving a hearing aid speaker !!
