| Class D Switching Power Amplifiers and Power D/A conversion |
Hi all
First of all - i am new here, so i don't really know if this is the right place to post this Well, here goes.. My plan is to build a stereo for outdoor use, mostly festivals, and it need to be able to play for 100+ people. As it's for festival use i want it to use as low power as possible, if a stereo with this size is able to do so. The idea was to build a setup with two X1's in the bottom with a Void V18-1000 or a PAudio SD18 driver, and two DR250's on top - don't know witch drivers to use here yet - any suggestions? My question is - do you think this will work together? And without using any more speakers? I would like to use a class d/t amp to the setup - is that possible? if so, could you recommend any? Furthermore the whole thing is supposed to go on 12v batteries, as it is a festival stereo - again, is it possible? I know it was a lot at one time, but i hope you will help me out here, i really need it. Best regards Christian |
#2 |
Your tweeters have an 4 ohm impedance, and your woofers have 8 ohms.
The tweeters seem louder to me (at 1w/1m), so if you parallel 2 woofers, you would not need any L-pads, and the resistance will be equal all over the spectrum. This way you can achieve a stable 4 ohm load, which is preferrable with outdoor use, due to low voltage of batteries. You might take a look at the new T3 amplifier coming up in the "New tk2050 board" tread, which is asymmetrical voltage on 48v (only 48v and ground/0v required), and has a power output of 300w into 4 ohms. Edit: just read about the 12v battery. You might consider using a converter, which can easily be combined with one of their amplifiers. Last edited by teamacc; 12th July 2010 at 01:53 PM. |
#3 |
Hi Christian
Of course it all depends on how loud you want it to get. Covering 100 people at a good level with 12 volts is possible with very efficient speakers. But from a practical standpoint, it just does not seem realistic. Power will be very limited. You have picked nicely efficient speakers, but with only about 8 watts and outdoors, you are going to run out of power fast. It will work, but will not be "slamming". What are your goals with the sound system?
Take the Speaker Voltage Test! |
#4 |
We have a tent at 8x4 metres where the stereo is supposed to be, and 50-100 can be. Besides that we just want it to play real loud!
- and with a good quality as well. We have severel batteries, and we do charge them along.last year we had a stereo with car speakers, amp and so - it worked fine but we want to upgrade it a lot now |
#5 |
And what do you mean with only 8 watts?
#6 |
Ohm's law, my friend. The most you'll get out of a 12V system into 8 ohms is about 8 watts RMS. Double that into 4 ohms. Peak will be higher, like 15 watts.
For higher power, you need more voltage. Big car systems use a DC/DC step-up power supply to make higher voltages. It's inside the amp. Maybe you should look into a nice car amp? Otherwise use 2 or 3 batteries in series for the higher voltage and an amp that can run at those higher voltages (as stated above).
#8 |
teamacc - sorry I missed your link. Yes, that's the sort of thing. Then find a Class-D amp that can run on +/-50V. Or buy a car amp.
#10 |
So what i could do is buying a converter (like the one linked to), buying a t-amp (like you linked to) and still using the 12v batteries and the speakers i picked?
Or, could i use a car amp instead and then do without a converter? And then just use more batteries? |
| Project: Building a portable outdoor-stereo | Rallen | Class D | 6 | 10th June 2010 06:08 AM |
| best sub for outdoor use | soundhead | Subwoofers | 20 | 6th January 2010 08:50 PM |
| Outdoor Theater Line Array Speaker Project | jcuria | Parts | 0 | 1st December 2009 05:10 AM |
| Spring project.....huge outdoor horn | weikertball | Subwoofers | 40 | 9th January 2007 12:11 AM |
| Page generated in 0.11699 seconds (84.69% PHP - 15.31% MySQL) with 10 queries |
