Curing Arjen helder amp power off pop !!!
Old 30th June 2010, 09:47 PM   #11
onis_uk is offline onis_uk  United Kingdom
Primary
0v – 200v – 220v – 240v
Secondary
0 – 22volts @ 2A
0 – 12volts @ 7.5A
surely that means 240v input and cant i just use the 12v 7.5 secondary to power the amps ?
Old 1st July 2010, 02:04 AM   #12
ArjenShenzhen is offline ArjenShenzhen  China
Send a message via MSN to ArjenShenzhen
Hi there Onis,
Please consider the following,
1- in my eye's torroidial transformers are ideal, as long as a good secondary stage has been implemented with a proper bridge rectifier and big buffer capacitor.
2- if you rectify AC to DC, the voltage increases, the is roughly calculable with AC X 1.4 = DC, but the rectifier also eats about 1 volt usually.
best case you find yourself a 10V ~ 11V Transformer, thats right about good, and if it has 5 A max, its plenty!
Greetings!
Arjen Helder
Always check the power supply... and my spelling...
Old 4th July 2010, 02:11 PM   #13
TheDealer is offline TheDealer  Germany
Hi Arjen,
I suspect you missed my eMail I sent you days ago regarding your new speaker output relay board. If you donīt know who I am please PM.
I would be pleased if you would act on this issue. I disconnected the buffer amp + MK III TA2020 system meanwhile and would be happy to build up an well working system in a case soon.
Old 4th July 2010, 02:20 PM   #14
Hi , O.K. I have read this meanwhile from onis_uk:
Arjen Helder Buffer V2
I am waiting till the technical issues cleared up completely.
Old 7th July 2010, 07:39 AM   #15
Ipanema is offline Ipanema  Malaysia
Ipanema's Avatar
Default humming
Hi, I got the TA2020 version 2.0A and tube buffer V1.3 board. It got quite a loud low Hz hum even when volume pot is fully turned down. Does anyone have this problem? I've tried this tube buffer with other power amp, but the hum still does exist. Regards.
Old 7th July 2010, 12:39 PM   #16
Hi there Ipanema,
you could first of all double check your grounding for the input signal and power supply, and second of all, on the PCB nect to the potentiometer there is a via that is put there to ground the metal parts of the potmeter. you can scratch some coating away and solder a wire fron the via to the pot housing.
if you cannot solve it, you can send me a photo of the set-up and ill scan that for any connection trouble.
Greetings,
Arjen Helder
Old 7th July 2010, 02:04 PM   #17
Ipanema's Avatar
Hi Arjen,
Thanks for your reply. The humm is gone after I change the 12V wall-adapter from the transformer type to SMPS type. Both are rated at 1A, 12V DC and does not comes with earth pin.
I can't find the output relay board on your ebay store. How much do you sell it?
Regards.
Old 8th August 2010, 01:33 AM   #18
Default Arjen is seems to be in vacation...
maybe another expericenced member can help me how to connect the relay board to the TA2020 mkIII-board
The pic here from arjen:
http://www.diyaudio.com/forums/class...ml#post2231104
makes me a bit unsure regarding the powersupply connection ... instead of L or R he writes Input + and - . Thatīs really confusing and seems not to be well calculated before...
BTW: Arjen seems to be in vacation because I must start here the same question after he didnīt reply to my PM message
Old 8th August 2010, 10:32 AM   #19
im sorry but i fail to see how that picture is confusing? its rather basic ... 12v to power the board and then the relays cut the + speakers wires !!!!
Old 8th August 2010, 11:38 AM   #20
AP2 is offline AP2  Italy
Banned
Hi All,
I think these amps that can go low voltage / battery is better to use a small relay directly to the output signal of the preamp (use a switch to disable when gnd). this is a more elegant but requires a simple circuit lm339. .. or brutal connection of the small relay at switch (ON-OFF VCC) with a small constant R-C.
P.S. it is possible use a FET for switch to gnd signal from preamp-out.
Curing Arjen helder amp power off pop !!!Hide this!Advertise here!
Helder MKII TA2020 Amp PSU Wiring Obe1 Class D 10 22nd January 2014 02:33 PM
Arjen Helder Buffer V2 Zero One Class D 72 19th May 2013 01:45 AM
Good Experience with Arjen Helder mfong Class D 6 10th May 2011 08:07 PM
6922 -- curing the ultrasonic RIAA blues jackinnj Tubes / Valves 9 31st January 2008 04:28 PM
buzzing and pop sound when fender power amp is turned on zaboomafoo Everything Else 0 27th August 2004 06:12 PM
Copyright ©1999-2017 diyAudio
