English class D pro audio amp
Old 26th June 2010, 08:03 PM   #1
aandy is offline aandy  United Kingdom
Default English class D pro audio amp
please can some one explain the wave forms of the test results on this amplifier,think they are poor and are they typical of class D
HTTP://www.abeltronics.co.uk/amptest...f60Q_-_ffa6004
look under amp testing
Old 26th June 2010, 08:43 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Not typical of decent class-d, it's poor amps like this that give class-d a bad name.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 27th June 2010, 06:37 PM   #3
SOSx is offline SOSx  United Kingdom
Hi Andy,
If you have been looking at this then I am sure that you have also seen the other tests by Abeltronics? He has tested various Class D-amplifiers and only a few have shown these sorts of severe results on a scope. Namely Powers oft and PKN.
I myself run large Lab Gruppen Class D (ish) amps that exhibit none of this.
I myself have also tested the amps in question in blind ab tests (well the 4004 version from FFA) and was not happy with the sound quality. We found its sound to be hard and abrasive above about 3-4k.
There are most definately good and bad ways to design all topologies
Kindest Regards
Old 27th June 2010, 09:06 PM   #4
I have tested the labs,they are class G were the booster(tracking supplies are pwm based buck converters) are tracking unlike the switched class H.
I like the labs But i am shocked by the utter lack of consideration as too the quality of this amplifier on the albertronics sight.
I used to design Hi-Fi amplifiers many moons ago.
and these days some manufacturers just produce utter Junk.
I think the customer will lose out,maybe the PA industry needs to be well cleaned up.
Old 27th June 2010, 10:06 PM   #5
I was wondering if you would pick up on the Lab Gruppen topology comment.
I thought that that must have been you Andy!
I told you that these amps were hard and abrasive and really do not compare with the PKN and Powersoft current class D designs.
In case you hadn't realized, Tim From Secrets Of Sound Here.
Hows development going?
Hadn't heard from you or Matt in a while?
How are you by the way?
Old 28th June 2010, 12:13 PM   #6
Workhorse is offline Workhorse
Workhorse's Avatar
A poorly implemented Class-D by those "Engineers" who think designing a switching amplifier is same as linear amp.
The result is obviously as crappy as one could expect.
Whereas,
When things are neatly engineered, the results[My 5KW CLass-D] are somewhat Cool
Old 28th June 2010, 05:01 PM   #7
AudioTechs is offline AudioTechs
Banned
Whereas,
Robust results Workhorse.
Keep the good work
Old 28th June 2010, 05:24 PM   #8
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The output signal shown by Workhorse is pre-clipped, it's a valid method to obtain clean clipping, but it does not reveal actual amplifier behaviour.
I use to feel like the small child in The Emperor's New Clothes tale
Old 28th June 2010, 05:25 PM   #9
Workhorse's Avatar
Default neighbours envy , owner's pride
Evita, its not "Preclipped" at input or anywhere else , i use another technique to get STICK FREE CLIPPING
Old 28th June 2010, 05:35 PM   #10
81bas is offline 81bas  Germany
Whereas,
would you be able to achieve the same results in clocked design with 25-30 dB of loop gain at 10kHz?
English class D pro audio ampHide this!Advertise here!
FS Pro Audio drivers from B&C and FaitalPRO augerpro Swap Meet 2 5th July 2009 03:46 AM
[UK] 2x Pro Audio C12 - 300MB & 2x Pro Audio PST888 Tweeters for Sale makksus Swap Meet 0 3rd November 2008 12:12 PM
Audio Dac with schematic (non English) gmphadte Digital Source 5 30th April 2004 09:19 PM
Higher power amp PCBs for pro audio? massappeal129 Solid State 2 10th February 2003 12:24 PM
Can a pro audio/dj amp be used with a subwoofer? WolfmanX Subwoofers 7 28th November 2002 02:10 AM
Copyright ©1999-2017 diyAudio
