| Class D Switching Power Amplifiers and Power D/A conversion |
I bought an Audigy 2 Value (SB0400) for measuring ClassD amplifiers, and there is a strange thing: on output I see a high freq noise with quite high amplitude (80 mV). It's spread between 60 and 300 kHz. Is it normal? Would anybody check his/her similar soundcard?
#2 |
Hello Pafi ...
I have Audigy 2 ZS paltinume edition or something like that. What is the name of the software u use for FFT with the soundcard? Regards,
1'st rule of chess: The only way to get smarter is by playing a smarter opponent. |
#3 |
Hello!
Yesterday I measured on an other card, EMU1212, and it has the same issue, so it's not unique. I measured it with oscilloscope. FFT is not neccessary, however useful. You can't check the sound card with itself, since there is a low pass filter on input with ~40 kHz corner freq. |
#4 |
Did you measured EMU1212 in the same your computer? maybe it is an PSU or motherboard issue, which produces such "side effect"?
#5 | |
#6 |
I heard, some audio cards are using so called 'jack sensing' feature, to determine, what was plugged in - microphone or headphones, etc... Maybe this does produces such a problem? Is this HF signal presented at the card output all the time during PC startup? Is this noise present during playback of some track at low volume level?
Very interesting problem
#7 | |
#8 |
Maybe, but NOT at this level! He is talking about 80mV form a total of 2000mV. That is some 28dB! What DAC has this level of noise?
#9 |
For example CS4392 (EMU0202).
#10 |
when measure output noise what is parameters (samples/sec)? I know Audigy 2,flat-108dB up to 46KHz. noise have relation with samples/S (non linear) because board use multiplier clock divisor . plus dac not professional.
| Upgrading from Audigy 2ZS? | cjv998 | Digital Source | 4 | 17th July 2007 02:41 AM |
| Audigy 2ZS soundcard | pinkmouse | Everything Else | 9 | 14th November 2006 09:26 AM |
| More Audigy 2 Warning | fmak | Digital Source | 5 | 9th February 2003 01:49 PM |
| Creative Audigy 2 | fmak | Digital Source | 15 | 26th January 2003 07:29 PM |
| Digital out on Audigy 2 | maczrool | Digital Source | 1 | 2nd January 2003 05:36 PM |
| Page generated in 0.09638 seconds (75.39% PHP - 24.61% MySQL) with 11 queries |
