Go Back   Home > Forums > Amplifiers > Class D
Old 20th June 2010, 12:58 PM   #1
lenni is offline lenni  Germany
Default HLLY TAMP 90 white noise / hiss issue
Hi all!
I just got my HLLY TAMP 90.
On the one hand I am impressed by it's sound/quality.
On the other hand I am disappointed because it produces a hiss / white noise which
is clearcly audible even if sitting 4 meters away. My loudspeakers are not overly sensitive.
The noise is there constantly. It varies a bit when changing the volume.
Anyone having a solution for this problem (other than buying another amp ;-) )
Thanks in advance
Lenni
Old 20th June 2010, 04:31 PM   #2
What are your speakers? I've had one of these,and used it on 94dB/w speakers.There is a little hum and hiss,but only with my ear up to the cone.Did you buy this new from Hlly? If so,it may be faulty or you may have been sent an earlier version.Can you open it to check what it says on the circuit board?
Old 21st June 2010, 07:31 PM   #3
My speakers are the Heco Superior 630
  • Belastbarkeit (Nenn-/Musikb.): 110 / 140 W
  • Wirkungsgrad: 88 dB/1W/1m
  • Übertragungsbereich: 32 - 35.000 Hz
  • Übergangsfrequenzen: 300 / 2.500 Hz
  • Impedanz: 4 Ohm
Old 24th June 2010, 06:35 AM   #4
HLLY offered me a very satisfying solution for the problem.
That's what I call excellent customer service.
Thanks!
Old 26th October 2010, 07:56 AM   #5
Send a message via MSN to hllyelec
New TAMP-90 do not have the hiss problem!
Hlly Tamp-90 Ta2022 Chip "a True Pearl" Tripath07 Vendor's Bazaar 179 18th June 2011 02:13 PM
Phono EQ hiss/white noise!!! chanwoo Tubes / Valves 10 24th March 2010 09:59 AM
The HLLY TAMP-90 : TA2022 tryout Neomatth Class D 5 18th January 2010 01:32 AM
The HLLY TAMP-20 : TA2020 tryout Neomatth Class D 23 4th August 2009 10:09 PM
HLLY TAMP-90 90W Class T AMP AMPLIFIER Tripath TA2022 hllyelec Vendor's Bazaar 2 19th January 2009 01:16 PM
Page generated in 0.07235 seconds (73.71% PHP - 26.29% MySQL) with 10 queries
