| Class D Switching Power Amplifiers and Power D/A conversion |
Is there any specific technical reason why most of Class-T and TDA designs use SMPS power supplies? I know the obvious ones such as probably low cost, size and efficiency.... Other than these? Or Is there any technical problem in using EI transformers to make power supplies for say an amp based on Tripath TA2024 chip or NXP TDA8930BTH chip? Thanks, Ron P.S:- This question probably have been asked here before, had I located the T-Amp FAQ, I probably could have avoided posting this thread. But the FAQ is nowhere to be seen. |
#2 |
Many Class-D designs have bad PSRR (power supply rejection ratio), even many selfoscillating designs...
So it is almost always preferred to use some kind of regulated power supply for class-D amp, I would say...
#3 |
Here is a monster I built using EI core transformers.....
IRAUDENSTEIN: A parts bin monster It was built for potential subwoofer duty, but it sounds surprisingly good used as a full range amp. The outputs are almost dead quiet without an input signal. EI pros: High input DC immunity Lower bandwidth = less line noise on the outputs Low inrush current EI cons: Larger size/weight Higher stray magnetic fields They like to hum
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#4 |
IRAUDAMP is exactly an example with very good PSRR value, since it uses an integrator in the feedback path, which provides very high loop-gain...
#5 | |
#6 | |
@81bas:- So what do you think about using a EI transformer without a regulated power supply for a TA2024 amp running on Single rail supply? The amp can operate between 10-16v easily I guess... Thanks, Ron |
#7 | |
Lower bandwidth? Maybe, but it has only 6 dB/octave slope, while an SMPS has 2 filter stages (12 dB/octave) at least! Low inrush current? Yes, with soft-start circuit. But SMPS can also has soft-start circuit. |
#8 |
Pafi,
They were comparisons to traditional toroidal mains transformers, not SMPS.
#9 |
Have a TA2024 amp powered from a donut, linearly regulated to 12V. TA2024 has pretty tight voltage requirements (min 8.5V, typ 12V, max operating 13.2V), 16V is the absolute max before damage, not operating condition.
#10 |
Let me see if I understand this.
Class d amps generally use SMPS PS because they have low PSRR. Don't SMPS have a reputation for being noisy? Wouldn't that be a bigger problem with a class D? I thought that people used SMPS with class D for the weight savings + some archaic notion that you need to use "like" with "like". Sort of like the old school tube guys.
http://www.caraudioconnoisseur.com/ |
| R-core transformers poor choice for amp PSUs? | Bosk | Power Supplies | 12 | 24th September 2009 10:29 AM |
| Cheap SMPS PSUs for class D modules. | Spasticteapot | Class D | 10 | 18th December 2006 03:33 AM |
| Hacking SMPS PSUs? | Spasticteapot | Power Supplies | 4 | 20th November 2006 03:40 PM |
| EI transformers. HEAT? | Aunkst | Parts | 2 | 22nd April 2004 05:07 PM |
| EI Vs Toroidal transformers | pcn | Pass Labs | 20 | 14th June 2003 01:36 AM |
| Page generated in 0.12412 seconds (81.77% PHP - 18.23% MySQL) with 10 queries |
