| Class D Switching Power Amplifiers and Power D/A conversion |
I am building a class D amplifier as a school project, next monday we should demonstrate our results. Yesterday I got my amp working for a minute. But then... well, lets say I will be more carefull with my screwdriver in the future Unfortunatly my IR2011 mosfetdriver died, but luckily my mosfets and Pwm-circuit still worked. So I needed a new driver-IC. But the delivery will not be for next week ![]() So as a quick solution I tried to design my own driver. Now, my question is: will this work? Or does someone have an other solution? Thanks. |
#2 |
No, unfortunately this will not work
You need to implement some level shifter for high side driver, and increase VIN amplitude to 0-10V (instead of 0-5V) to make low side driver working... How do you produce the PWM signal? is it referenced to the ground or to the -VCC (-40V) ?EDIT: did not seen, that the low side driver is not a totem pole follower... So you need to increase VIN even to 0-12V and you will get huge shot-through currents in the low side driver with such configuration...
#3 | |
#4 |
Take a look at the original UcD circuit, to get an idea of how to make a discrete driver circuit .... I'm afraid it will take much more time than you have available
![]() See here at my home page Micro class-d amplifiers UcD / Hysteresis where you'll find both references and an implementation ... Go find that IR2011 at some other place with faster delivery ... that is a better option
#5 |
Jelle you can use MIC4420 chip as your class-d output stage if your power output is less than 20W and suffices well for your project. Though its a gate driver but it can be used to demonstrate class-d working concept.
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#6 |
Thank you for the replies,
I am now searching for a way to just get the PWM amplified with discrete components or a standard chip, just to demonstrate the working principle. A complicated circuit like the UcD will take to much time to build and test. The MIC4420 would have been a good solution, when I had a little more time. Thanks. |
#7 |
If I were you, I would replace upper FET to p-channel, this way it's easier to drive.
#8 |
#9 |
It looks like the pictures don't work?
Imageshack - screenhunterjun12210203.jpg Imageshack - screenhunterjun12210204.jpg |
#10 |
Just attach your pictures!
Working? What output voltage do you expect from the power stage? |
| Will this work? | SState13 | Multi-Way | 19 | 29th October 2009 08:30 PM |
| will this work | rtill | Solid State | 24 | 26th March 2009 12:47 PM |
| Why wouldn't this work? | millwood | Solid State | 34 | 13th July 2003 04:03 PM |
| Page generated in 0.12168 seconds (73.17% PHP - 26.83% MySQL) with 11 queries |
