| Class D Switching Power Amplifiers and Power D/A conversion |
Hello developers,
if you want to build an amplifier with very high resolution for jazz and classical music then it is now very easy with this module PWM, this also solves the PCB, I can assure you that with a pre-fiberglass board you get a sn / r-100dB. I have attached a simple amplifier just to see the phase and the connection that is needed (very simple). This PWM module with another type of power stage (no IR21xx) has a THD of 0.002% at 100W out (4R). ![]() forms are available at a cost of components, but when I do not know how you can buy. We'll let you know as you may have. Regards |
#2 |
is it selfoscillating or clocked?
#3 |
#4 |
Banned
The outer feedback loop is for DC-Offset correction ![]() Kahn |
#5 |
#6 |
Hi All,
I cecked scheme and now it is correct. A short i put PCB with this identical scheme and measures, just for demostrate that it work perfectly and stable, sure, it possible connect this modulator at professional power stage (not IR21xx) for very professional performances. but with this simple low cost scheme i listen with very surprise in definition of sound. With this scheme,modulator is capable di clip at (vcc rail-700mV) ,super nais efficiency! ![]() Regards |
#7 |
Modulator on amplifier (TRW-scheme) Regards |
#8 |
Banned
Hi, it means the output power bandwidth of amplifier is not independent of load impedance connected. It will give different response with different loads, because the outer loop does nothing for audio, all it does is for dc-offset.
#9 |
Is there any info about loop-gain / PSRR for this modulator available?
#10 |
Banned
| DAC approaches for high-res | montesquieu61 | Digital Line Level | 10 | 15th January 2010 12:16 PM |
| High efficiency hi-fi speakers, DIY suggestions? | Pirium | Multi-Way | 52 | 4th February 2008 05:41 AM |
| Equilog PWM amplifier module? | TroelsM | Class D | 7 | 11th November 2005 11:32 PM |
| Class D,T or whatever (pwm amplifiers) | HaaiFaai | Solid State | 26 | 23rd February 2002 07:51 PM |
| Page generated in 0.11734 seconds (75.12% PHP - 24.88% MySQL) with 11 queries |
