| Class D Switching Power Amplifiers and Power D/A conversion |
Greetings,
I'm planning to make a couple of amps with TAS5630. "On the side", for one reason or another, i've been collecting and scavenging an assortment of old and/or broken computer PSU's, and as such, i've put together quite a stock of toroidal cores. Judging by their color coding, mostly mix -26 and -52 (according to Micrometals color codes). I'll be running the amps in 2xBTL per each chip. Now, considering that some board-space-saving wouldn't hurt, my question is, is there some way to wind a coupled BTL output inductor, without blowing anything up? I've got the "mini ring-core calculator" and Micrometals' inductor design/analysis program, to help. |
#2 |
Hi!
This is a solution (attached). |
#3 |
#4 |
Very good drawings and explanations!
![]() However I had no success to use coupled inductor in BTL configuration with BD modulation mode earlier... It was working only with AD modulation for me. And the inductor was wound slightly different, than in your drawings. You have shown the 'common mode' inductor (input currents are always in phase), whereas for AD modulation I have used the 'differential mode' inductor (input currents are out of phase). Please correct, if I am wrong.
#7 |
Oooooh, yeah
![]() Am i right with my hunch about the core dimensioning, though? |
#8 | |||
Input currents are out of phase in my case also, but there is a common mode component too at switching freq. This common mode current would be huge with separated inductors, because of the low switching freq, this is one of the reasons I used this kind of filter. With AD modulation higher fsw is needed, this because the ripple current is not too high. Khron! Quote:
#9 |
Pafi, the TAS5630 can work in either AD or BD modulation, in the 2xBTL configuration.
The top sketch in your posted pic resembles how the windings look on common-mode inductors, on SMPS inputs, so i'm guessing the bottom sketch is the differential-mode winding? So that's how a coupled inductor for a bridged amp should be wound? Or... Which type of modulation should be configured, for which type of winding? ![]() And by "one end shorted", i guess you mean with one of the windings shorted, on a "double-wound" toroid, right? (Better safe than sorry )
#10 |
Note that in the bottom sketch (AD) the flux is always contained within the core, while on the top sketch (BD) the flux becomes progressively spread everywhere (as in a pair of air core inductors) as output voltage becomes higher or lower than 0V.
I use to feel like the small child in The Emperor's New Clothes tale
| Function of Output Inductor | caesar148 | Solid State | 360 | 19th April 2010 09:01 AM |
| coupled output inductor in dual smps | schiller | Power Supplies | 4 | 7th April 2010 08:10 PM |
| BTL output filter | ted12 | Class D | 16 | 26th April 2005 01:55 PM |
| Source for output air cor output inductor?? | sam9 | Solid State | 7 | 19th January 2004 02:25 AM |
| Page generated in 0.11390 seconds (79.78% PHP - 20.22% MySQL) with 11 queries |
