| Class D Switching Power Amplifiers and Power D/A conversion |
Its time to redesign my 4 years old Icepower based power amp.
![]() Inside an old amplifier really reminiscent of bird's nest, but it worked without any errors. ![]() I will use B&O Icepower 250A with analog PSU and 250ASP modules. I decided for the following configurations: -Dual mono amp. with analog PSU -Dual mono amp with ASP modules + balanced signal preamp! -2 X mono amp. with huge PSU. For stabilised 2 X 12V I will use excelent LCaudio design lownoise PSU. Housing design will be similar to the well known Danish manufacturer.....black anodized aluminium + stainless steel front and top ahhhh! ![]() ![]() Jazzy
J.Z. |
#2 |
Internal topology of future amplifiers!
J.Z. |
#3 |
Dual mono amp is almost completed.
But I have to wait for the delivery of OPA 2604. Because of excessive voltage from the transformer( 2 X 17V AC instead of the 2 X 15V), I must replace the NE5532 with OPAs in the Low-Noise regulator !
J.Z. |
#4 |
Quick look at the outward appearance........
J.Z. |
#5 |
looks great so far!
#6 |
indeed
#7 |
I changed the transformer low-voltage secundar to 2 X 15V.
Low noise reg. is now OK. ![]() Amp. ready for first listening test!
J.Z. Last edited by jazzy; 15th June 2010 at 05:14 PM. |
#8 |
2 X 250ASP modules prepare fot test ride
![]() Add extra capacitors( Elna for Audio 60.000uF) for better performance!? ![]() Next week I will finish and installed preamp modules too!
J.Z. |
#9 |
First monoblock ready for test!!
J.Z. |
#10 |
Left and right monoblocks are ready for test!!
J.Z. |
| Major amp circuit redesign- need some expert advice | ambience exists | Tubes / Valves | 6 | 13th June 2009 09:16 PM |
| Tube phono amp repair/redesign help wanted | dikarner | Tubes / Valves | 67 | 4th August 2008 06:33 PM |
| Headphone Amp Redesign? | orangeshasta | Headphone Systems | 9 | 10th July 2007 05:12 PM |
| redesign amp need | prorms | Solid State | 9 | 17th June 2006 08:35 AM |
| Page generated in 0.12920 seconds (71.63% PHP - 28.37% MySQL) with 11 queries |
