| Class D Switching Power Amplifiers and Power D/A conversion |
please someone verify my board it is made in eagle
#2 |
SINEWAVE ELECTRONICS CO.,LTD
I have check your eagle file just ago,For my experience you should attention four key point.
1. TAS 5630 can deliver out so large power,output inductor and capacitor should big enough,common parts used in lower power class D amp not perfect. 19A ripple current for inductor and capacitor. I think your selected inductor and capacitor not perfect. 2.Pvdd should added at middle line of four energy electric capacitor,otherwise peak swith current not balance,maybe one channel output MOSFET burnt at heavy loader . 3,All the power pcb line and output large current route should smart and smoothness transition zone.forbid route width saltation. 4,Buffer OP amp as near as tas 5630,not suggest divided two board. other key point you have to attention is heatsink design.but it easy. I think you will finish one excellent class D amp with TAS5630PHD,if you have other questions,send mail to me. Last edited by authlxl; 22nd May 2010 at 02:10 AM. |
#3 |
Thanks for your advice, I will increase the track width for the power line and output line. The capacitor I selected is 1000uf/63V type, and the inductor I planed for drum core.
I am planning for my sub amp, same input for both channels |
#4 |
add extra tracks for PVDD
#5 |
My major concern is the large slot bisecting the ground on the bottom layer of the board.
For switching circuits it is highly recomended to have a contiguous GND plane with no slots. This could cause some serious EMC problems, and may stop the circuit working at the optium. It may not be easy, but wire links would be better than the track that cuts the plane. http://www.ultracad.com/articles/slots.pdf Grounding of Mixes Signal Systems Slots in Ground Planes Circuit board layout guidelines for Class-D amplifiers | Audio DesignLine |
| Tas5630phd module only sell USD25 | authlxl | Swap Meet | 5 | 24th January 2011 12:09 PM |
| Please some on verify Adcom GFA 585 Input board caps(c165, c164)? | birdyman | Solid State | 2 | 19th December 2010 08:37 PM |
| Please, verify my math. | ostie01 | Multi-Way | 5 | 24th January 2007 04:21 AM |
| Page generated in 0.09194 seconds (70.31% PHP - 29.69% MySQL) with 11 queries |
