| Class D Switching Power Amplifiers and Power D/A conversion |
Greetings,
I've been playing around lately with various setups and a TA2020 board (from Arjen). I have an opprtunity to buy a pair of Cambridge Audio's highly recommended S30 bookshelf pair for a small/medium living room with 50/50 Movies/Music usage (moderate listenning volume and a separate Subwoofer). http://www.cambridgeaudio.com/assets...sedreprint.pdf Would the TA2020 board be up to the job driving them w/o significant decrease in sound quality? or shall I consider them only with a more powerfull board (i.e. TK2050 or TI5613 variants)? The S30 Spec. are: Sensitivity:90dB Frequency Response:55hz - 20kHz Nominal Impedance:4-8 Ohms Drive units:Tweeter: 1 x 25mm (1”) Woofer: 1 x 115mm (4.5") mid/bass driver Crossover:1st Order 2 way Recommended maximum amplifier power:100 watts Ported:1 Rear Magnetically shielded:Yes Dimensions (H x W x D):226 x 160 x 235mm (inc. grill) (8.9 x 6.3 x 9.2”) Weight:3.75kg (8.3lbs) Thanks, Gal |
#2 |
My generic TA2024 amp does a decent job of powering a set of Boston Acoustics speakers with similar specs (8 ohm, 90db sensitivity, 4.5" woofer) in a small to mid-sized room. Since the TA2020 is slightly more powerful, you'll probably get similar results, but the only way to know for sure is to try.
#3 | |
![]() I just wanted to collect other people insight before I spend my $$$ and commit to buy unsuitable HW. Any other experiences ? Gal |
| Ask review Cambridge S30 | in2isee | Multi-Way | 5 | 9th April 2010 08:40 AM |
| Zaph audio's ZD5 | dukeoddorkdom | Multi-Way | 1 | 24th March 2009 10:24 PM |
| Gemme Audio's VFlex | LilMik | Multi-Way | 1 | 18th February 2007 10:30 PM |
| Wisdom Audio's new woofers | studiotech | Planars & Exotics | 9 | 25th January 2005 11:05 PM |
| Page generated in 0.07565 seconds (67.82% PHP - 32.18% MySQL) with 10 queries |
