| Class D Switching Power Amplifiers and Power D/A conversion |
I have build my amp following this Schematic . Sound is good but when it was running at high level (volume up) ,Mosfets was blow. What is wrong in schematic?
Need suggestions. |
#2 |
Greetings Opor,
At first glace something looks odd to me with that gate driver (IC2). Some of the pins marked NC are being used - NC usually means "no connection", I thought. Also, pin 3 is marked VCC, but is connected to +12. Also, COM is connected to VSS, which seems odd to me. U1 also has examples of NC pins in use. To me there is certainly a few things which are odd about this schematic, but I am fairly new to class D. Still, is this a proven design? Jim |
#3 |
Your Mosfet have a great input capacitance(5,4nF). So your gate resistor must be lower than 100 ohms (you can try with 10 ohms). You have to increase C10 10uF for example but with a low ESR What is your supply voltage VCC ? |
#4 |
my supply is +-65V
#5 |
And the inductor and fets are so hot.
#6 |
OK In this case you can use IRFB4019. This MosFet is more suitable in your design.
Otherwise if you still have problems may be a dead-time would be necessary to avoid cross-conduction |
#7 |
If your inductor is hot, may be inappropriate magnetic circuit is used!
What is your magnetic circuit? How many turns? And what is your impedance load? |
#8 |
I wonder that the feed back resistor too high so I have decrease it to 47K but it is still hot. IRFB4019 is hard to get here. Any substitutions?
#9 |
At first I use 18uH terroid core as mention in the schematic.But it get hot quickly. Now it is 55uH and it seem colder but still hot which could not be with class D amp.
#10 |
8 ohm load.
| Did I blow the tubes ? | Nikon1975 | Tubelab | 18 | 31st January 2010 03:12 PM |
| NAD fuses, slow blow or fast blow? | AllCaster | Solid State | 3 | 25th October 2009 06:11 PM |
| Blow up once, Blow up twice and Blow up somemore | S.C | Chip Amps | 14 | 6th March 2005 12:09 AM |
| Will This Blow Up? | Trout | Tubes / Valves | 8 | 6th February 2005 12:52 PM |
| Will it blow up? | dickerbeen | Everything Else | 1 | 17th April 2003 05:21 AM |
| Page generated in 0.11986 seconds (73.16% PHP - 26.84% MySQL) with 11 queries |
