Go Back   Home > Forums > Amplifiers > Class D
Old 6th May 2010, 12:19 AM   #1
nigelwright7557's Avatar
Default Class D IC recommendations wanted.
Looking to design a class D high power amplifier, upto 1000watts peak.
I looked at the IRS2092 but it is hard to get hold of in DIP for through hole.
The IRS2092 looks good becasue it is scalable using external buffers on the HO and LO outputs. Something similar would be good.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 6th May 2010, 12:53 AM   #2
theAnonymous1's Avatar
Your options are limited if you want an all in one modulator/driver IC like the IRS2092. They are even more limited if you can only design with through hole packages.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 6th May 2010, 12:56 AM   #3
An all in one does keep the pcb size down and requires less components.
I can get away with through hole or SMD taht isnt too small to solder by hand. A pitch of 0.05 is probably as small as I can solder with my old shaky hands !
Class D/Tripath amp recommendations? Hemisphere Class D 10 31st May 2010 12:41 PM
Recommendations for TO-92 5V reg IC luvdunhill Parts 3 23rd June 2008 06:00 PM
Wanted TA0104A Tripath Class T driver IC screamer Swap Meet 0 13th January 2006 10:07 AM
Need easy class A amp recommendations greg7 Solid State 8 12th May 2003 05:06 PM
mid range driver recommendations wanted Bill Fitzpatrick Multi-Way 0 5th June 2001 01:01 AM
Page generated in 0.07274 seconds (69.13% PHP - 30.87% MySQL) with 10 queries
