Go Back   Home > Forums > Amplifiers > Class D
Old 5th May 2010, 11:53 PM   #1
nfm is offline nfm  United States
Default aibuya's TA2022 Tube Digital Amplifier
Hey guys,
Is anybody using this kit? How does it compare to the others? What does "Tube" mean? New Enthusiast HIFI TA2022 Tube Digital Amplifier Hot!! - eBay (item 120556468320 end time May-13-10 10:54:25 PDT). Also where could I get the transformer for this kit? I guess I'm searching wrong keywords.
Thanks.
Old 6th May 2010, 07:00 AM   #2
Tube means it is using a valve on the input stage-vacuum tube to you Americans :-)
As for a transformer,the seller says he can supply one.If you want to get on yourself,you need one that will give two secondary supplies- a 20 volt center-tapped,and a 9 volt supply.Should be easy to source.
Old 6th May 2010, 07:55 PM   #3
Thanks for the reply,
I'm still researching and learning bit by bit, to me it looks like it's a top notch ebay TA2022 amp!
Old 6th May 2010, 08:57 PM   #4
Pano is offline Pano  United States
Pano's Avatar
Yeah, who knows if the tube does any good, but it should be fun and easy enough to try it!
Take the Speaker Voltage Test!
Old 6th May 2010, 09:19 PM   #5
hoka is offline hoka  Netherlands
Thanks for pointing it out!
I ordered one to try out my gold pin super boutique mullard e88cc
I'll let you know how it sounds
Old 7th May 2010, 04:11 PM   #6
Please do.I have the Hlly T-amp 90,which uses the same chip.This amp is good on it's own,but becomes excellent when used with my valve preamp,so this one may sound rather good.
Old 28th May 2010, 05:08 PM   #7
Galgo is offline Galgo  Israel
This looks REALLY cool !
Thank you for the head-up...
Anyone already listened to it?
Gal
Old 28th May 2010, 05:22 PM   #8
Yes, I have been listening to this amp unmodified except for the mullard e88cc and am very pleased with it. Usually new amps don't last to long before I put my old Charlize back in place. This one is going to last I think!
Old 28th May 2010, 05:31 PM   #9
Thanks - good to Hear
Any tips/insights?
Planned modifications?
Can you compare it to "standard" Tripath based boards i.e. TA2020/TA2022/TK2050 (or anything else you've tried)?
Have fun,
Gal
P.S. - What PSU did you use? SMPS or a Toroidal transformer?
Old 28th May 2010, 06:24 PM   #10
It is remarkably similar to the Charlize (a TA 2020) very neutral, you forget it is there unlike the icepowers gainclones and 2050's I tried. What comes to mind is my old Cyrus one, also an amp that does not force itself on you.
I have it hooked up to a 120 watts Toroid with a extra winding for the heater and it has lots of punch.
Connexelectronic TA2022 amplifier with FE167E (94dB/w/m) opinion? lhgin Class D 5 3rd August 2009 05:34 AM
HLLY TAMP-90 90W Class T AMP AMPLIFIER Tripath TA2022 hllyelec Vendor's Bazaar 2 19th January 2009 01:16 PM
Tube Output Full digital Amplifier KOON3876 Class D 8 14th December 2006 05:54 PM
Page generated in 0.09224 seconds (82.23% PHP - 17.77% MySQL) with 10 queries
