Go Back   Home > Forums > Amplifiers > Class D
Old 4th May 2010, 01:39 PM   #1
theAnonymous1's Avatar
Default My latest TPA3106D1 40W mono boards
I dedicate these boards to member Workhorse. I know how much he appreciates a good "chip amp".
The thing that really amazes be about these boards is how cool they stay. The inductors don't heat up at all and the entire board only gets slightly warm when playing near full volume for long periods of time.
These are my favorite pair so far. I've given up on the TPA3122D2; it requires extra circuitry for bridging and just isn't as good in many respects. It was fun experimenting with it though.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 4th May 2010, 02:28 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Very interesting. Did you make those, or are they eval boards you got from TI? (the logo)
Take the Speaker Voltage Test!
Old 4th May 2010, 03:03 PM   #3
Hi Pano,
I made these myself. I "borrowed" the TI logo from one of their PDFs using a PDF editor. I hope they don't mind.
I'm glad you popped into this thread though. I was thinking of letting someone else audition these so I can get a second opinion on how they perform. Interested?
Old 4th May 2010, 04:48 PM   #4
Pano's Avatar
Yes, I'd love to. Right now tho I'm not running a passive crossover, so can really only listen to them from about 500Hz up (horns) or 500Hz down (Altec woofers) Not sure if that meets your needs. Oh wait, I do have some nice floor standers that could test them.
Nice work on the PCB. I thought it looked home made, but the nice TI logo on the corner had me confused.
Old 4th May 2010, 04:52 PM   #5
von.ah is offline von.ah  United States
von.ah's Avatar
Jeebus, those are small! Quite an awesome little build. How do you think they sound compared to other lower-powered class D amps you've used?
Edit: yikes, those THD+N plots from the TI datasheet don't exactly look stellar... At least to this noob.
Old 4th May 2010, 05:13 PM   #6
Originally Posted by panomaniac View Post
Yes, I'd love to.
Great, just PM me your addy then. Give me about a week or so so I can find an enclosure to put them in so they are easier to handle
Heh, that's what I need Pano for.
I can only tell when there is some obvious flaw in the sound. I can pick out things like lack of bass (or lack of control), high noise floor, extreme sibilance, and high levels of distortion. Things like "resolution" and "soundstage" just get lost in my brain somewhere.
All in all, I think these sound great. Definitely no lack of bass, and with the lowest two gain settings the noise floor seems lower than the "T-Amps" I have.
THD is more complicated than just a number. You can't say an amp will sound bad just by the THD specs. Go look at the THD numbers for tube amps.
Old 4th May 2010, 05:46 PM   #7
I forgot to mention the DC offset on these is also considerably lower than most of the small Tripath amps (without offset adjustment). One has 5mV and the other 9mV.
Old 4th May 2010, 05:57 PM   #8
von.ah's Avatar
Right, I get that. Since we don't know what type of THD or N is influencing the plot most, we can't make assumptions on how that might relate to "sound." People tend to "like" tube distortion, whereas the output devices in these sorts of chips are tiny FETs, right?
But just as a quick apples to pears comparison, looking at the long time favorite TA2020, the TPA seems a bit wacky in the THD+N/frequency plot.
Just an observation.
Regardless, I admire your work.
Old 4th May 2010, 06:12 PM   #9
Yeah, it is a strange curve.
Anywho, not trying to claim this is some uber Hi-Fi T-Amp killer. Just another option (for me at least).
It is what it is; a budget, low powered, "fast food" packaged, class-d amp. Sometimes I really onjoy a good burger and fries though.
Old 4th May 2010, 06:44 PM   #10
von.ah's Avatar
Well put.
The small and simple form factor is certainly an advantage. These would be great for powered speakers.
Cheers.
40W class A push pull amp with JJ 2A3-40w possible? 3nity Tubes / Valves 18 26th May 2010 11:05 PM
40w Class A Circuit kaybe Solid State 3 23rd February 2009 09:47 PM
Sanken S-40w Jorgitox Swap Meet 4 13th February 2009 10:00 AM
LM4780 dual mono -- boards jackinnj Swap Meet 1 1st October 2008 12:44 AM
Classe A 6550 40W s2kov Tubes / Valves 5 17th February 2005 01:31 PM
Page generated in 0.12679 seconds (82.12% PHP - 17.88% MySQL) with 11 queries
