ucd 25 watts to 1200 watts using 2 mosfets
Old 1st March 2011, 05:33 PM   #901
Pafi is offline Pafi  Hungary
You're welcome! And thanks for feedback!
Old 1st March 2011, 06:06 PM   #902
NMOS is offline NMOS  Germany
NMOS's Avatar
Originally Posted by Pafi View Post
norazmi!
, and place Rg between emitter and base!
sorry... Im beginner what is Rg ?
Old 2nd March 2011, 04:43 AM   #903
Resistor originally in series with gate.
Old 3rd March 2011, 09:10 AM   #904
NMOS's Avatar
norazmi!
only the discharge needs to be made faster. Connect base to IR2110, collector to source, emitter to gate, and place Rg between emitter and base!
Hi Pafi
Im beginner and a little confused how to do mit BC327...
please check schematic..... is this ok or wrong ?
could you assist me ?
regards
Old 3rd March 2011, 11:34 AM   #905
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
Originally Posted by NMOS View Post
Hi Pafi
regards
The connection of the BC237s is OK, but you must erase D4 and D3.
By the way, do not use IRFP250N, the BC237 will make them discharge faster, but their body diodes are still very bad, so you don't really increase performance
(maybe you make it worse: this extra will make them switch faster, faster switching means higher dI/dt, so will mean more diode loss!)
Pafi's trick is appropiate for FETs with low Rdson, low Qcc (good body diode), but high Qgate. Its a very nice trick for other drivers such as IRS2092 (where 1A gate charge is enough, but 1,2A gate discharge should be made faster...)
Olyan nem volt még, hogy ne lett volna valahogy
Old 3rd March 2011, 05:17 PM   #906
kubeek is offline kubeek  Czech Republic
Send a message via ICQ to kubeek
I just had an interesitng idea, would it be possible to use this amplifier topology to create a free oscillating SMPS?
My idea is to use it in a full bridge configuration to crate the power rails for the actual apmplifier. Would the free oscillation frequency cause any RFI problems?
My goal is to design a compact scalable 100-500W PSU+amplifier to power bass speaker.
Any suggestions?
Old 3rd March 2011, 07:11 PM   #907
electroconico is offline electroconico  Mexico
Talking pcbs arrived
I've received my boards , they look great for me .
I´ll need time xD to build them.
regards!
ty ejtagle!
Old 3rd March 2011, 09:55 PM   #908
luka is offline luka  Slovenia
luka's Avatar
hope it works, build and test and report back
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 3rd March 2011, 10:00 PM   #909
lorylaci's Avatar
Any suggestions?
Its really off-topic, but yes, its possible. There are self-oscillating SMPS, they are mostly used at fluorescent lamps.
Skori Weblapja - Rezonns kapcsolzem tpegysg II.
Here is Skory's page, its in Hungarian, he is an expert in this topic, but im sure you will understand the schematics, and with google translator it will be better.
Old 5th March 2011, 11:51 AM   #910
NMOS's Avatar
Do It Yourself!
For high voltage (more than 200 V): diode trick, or IGBT is needed.
Hello, as beginner please can you teach me what is diode trick ?
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
