ucd 25 watts to 1200 watts using 2 mosfets
Old 2nd January 2011, 10:55 AM   #801
Dzony988 is offline Dzony988  Serbia
Happy new year to all!
Old 2nd January 2011, 03:12 PM   #802
stewin is offline stewin  Kenya
happy new year guyz and a prosperous 2008
Old 2nd January 2011, 03:27 PM   #803
ionutzxpo is offline ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
Happy new year!!
Old 4th January 2011, 07:18 AM   #804
happy new year guyz and a prosperous 2011
Old 8th January 2011, 03:58 PM   #805
Hi to all..
Do anyone have schematic of some simple smps +-50-60V 400-600W, i need for this amplifier
tnx
Old 8th January 2011, 08:42 PM   #806
NMOS is offline NMOS  Germany
NMOS's Avatar
Originally Posted by Dzony988 View Post
Hi to all..
tnx
better use transformer, because you will dont have power supply pumping problems and dont need overvoltage protection
Old 8th January 2011, 08:42 PM   #807
NMOS's Avatar
Does someboday have short circuit protection for this amp ?
Old 8th January 2011, 08:57 PM   #808
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
If you use enough caps, then you wont have pumping problems.
You can calculate sufficient capacitor values with: deltaU=Ubus/(8*Pi*f*Rload*Cbus)
The music power content under 70Hz is rapidly decreasing. Few kick drums are tuned/miked/eqd to sound under 70Hz, and bass guitar pickups dont get the first harmonic... so unless you design a sub amp for home cinema, and use sufficient caps (caps still cheap) supply bus pumping is not an issue.
Simple short circuit prot can be achieved by putting a shunt in and using a opto-coupler to supply Vn+12V to SD pin of IR2110, but the shunt dissipation will be higher than the main FETs dissipation, so this usual shunt method for Class B should not be used, unless you dont care about this small dissipation.
Olyan nem volt még, hogy ne lett volna valahogy
Old 9th January 2011, 12:10 AM   #809
No, I dont really care for this small disipation... do you have this schematic with sd pin, which has been verified, on example for +-60V for 350-400W on 4 ohm load
Thank you
Old 9th January 2011, 02:10 AM   #810
NMOS's Avatar
so please can you offer schematic for SD-Pin with IR 2110
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
