ucd 25 watts to 1200 watts using 2 mosfets
Old 13th December 2010, 01:33 PM   #691
Dzony988 is offline Dzony988  Serbia
Hi to all
I find at Farnell.com feritte cores, transportable in my contry and its cheap
Which of these cores can I use?
1) Multicomp 33RI 31.5x16x19
2) Multicomp 33RI 28x20x16
3) Epcos 25.3x14.8x10 material T37
4) Ferroxcube TN25/15/10-2E25
5) Ferroxcube TN32-19/13-3E25
6) Ferroxcube TX29/19/7.6-3E27
7) Ferroxcube TX32/19/15-3C90
http://www.farnell.com/datasheets/491631.pdf Datasheet for all Ferroxcube
http://www.farnell.com/datasheets/80884.pdf Datasheet for Epcos
Old 13th December 2010, 01:41 PM   #692
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Of the Ferroxcube materials you have listed, the only one which is intended for power applications is 3C90. The rest are intended for EMI suppression filters.
Search on the web for "Soft Ferrites and Accessories". This contains the full data on Ferroxcube cores and ferrite materials, and is a very useful reference.
Old 13th December 2010, 02:01 PM   #693
You mean Ferroxcube TX32/19/15-3C90?
Will it be enough to 500 600W 4 ohms? How many turns for this core for 20uH coil?
its cheap 2.06 pounds
Old 13th December 2010, 02:27 PM   #694
Ouroboros's Avatar
Yes, but this is an ungapped Ferrite toroid (not dust-iron), so it will need a gap cutting in it to prevent magnetic saturation.
The core will be (roughly) 32mm outside diameter, 19mm inside diameter and 15mm height.
if you cut a gap in it (with a diamond coated circular tile-cutter saw) so that it had an AL of 100nH, then my estimation is that it could tolerate an i^2*L of 4mJ. As an example, a 22uH coil carrying a peak current of 13A will have a peak i^2*L of 3.7mJ.
I have never tried gapping a ferrite toroid with a tile saw, so if you did that then you would have to wind a few turns on the gapped core and measure the inductance to determine the AL for the gapped core.
Old 13th December 2010, 02:30 PM   #695
Ouroboros's Avatar
Actually I wouldn't try to go above 400W into 4 Ohms, with this core gapped to give an AL of 100nH.
Old 13th December 2010, 04:54 PM   #696
I must to gap that core? how much? Some other feritte core without gaping for 400 500w into 4 ohms?
Old 13th December 2010, 04:58 PM   #697
Can I use any core from here without gaping
Farnell Export
thanks
Old 13th December 2010, 06:18 PM   #698
Pafi is offline Pafi  Hungary
Summed volume of gaps should be ~100 mm^2 at least.
No, it doesn't exist practically.
Old 13th December 2010, 09:45 PM   #699
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
Dzony988:
MUST USE GAP!
Buy two of these:
EPCOS|B66361G1000X187|FERRITE CORE, HALF, GAPPED, ETD34 | Farnell Magyarország
This will give you 2mm gap (170mm^3), wind it with 18 turns of multiple thin wire (as much as you can, but don't wind over gap), this will lead you to an inductor of 30uH with 43A saturation current. There is 94mm^2 winding space, and 50% effective space use (even if you wind it very nice), that means 2,5mm^2 wire-group, so if you do right the Rdc would be under 15mOhm. Should be pretty good over 500W 4 Ohm too...
Old 13th December 2010, 10:53 PM   #700
Laci!
I'd rather say 28 A! I prefer higher Ae, lower Aw, since core loss is always there, but audio load is rather weak.
But this is already much better than a 106-26.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
