UCD 25 watts to 1200 watts using 2 mosfets
hi opor
s greetings tried my board today bulb series does not glow in series
but on connecting speaker bulb glows so any voltage test points so i can find
thefault hoping you can help first d class very new to it
thanking you
andrew lebon
Hi everyone..
After long time I came to the forum and searched for a class D amp. I saw this thread in an accident and luckily. I have never tried a class D amp so far because of the complexity.. I'm really amazed by the design and really glad to hear that it works..
I dont care THD values and any other comparison of this with other amplifiers. because if you care of those, you better try there are many appreciated amps here. But I enjoy the simplicity, output power and the efficiency with this. I'll be really happy if I could get powered my woofers with this 🙂)
My plan is to drive a subwoofer from this with a low pass filter. mid and highs form another amp.
Thank you all for running this thread with helpful stuff.. Pro engineers please look at this and tweak it with the minimum complexity. your work will be appreciated. because DIY should to be simple otherwise it has to be "do it by others".. lol.. just a joke 😛 🙂)
regards,
Lycanlk
