ucd 25 watts to 1200 watts using 2 mosfets
Old 30th November 2010, 03:22 PM   #621
stewin is offline stewin  Kenya
hi guyz about the 106-26 core i managed to add the 1mm gap with a hacksaw . my supply is +/- 70vlts the core gets hot but i've been playing it for like 7 hours .despite of the heat every thing is ok mosfets irfp260 are warm but my load is 4ohms and i'm using a very small heatsink .
but i've noted if i increase the gap to 3mm distortion and crackling in high frequency at high volume disappears ican't explain it scientifically but it works great here are my layout and schema
Old 30th November 2010, 03:44 PM   #622
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
hi stewin
greetings can you share pcb pattern for this amplifier failed once
want to make it again to good to miss out
thanking you
andrew lebon
Old 30th November 2010, 05:27 PM   #623
Dzony988 is offline Dzony988  Serbia
Ok, thank you guys
Now I'm understanding this about gap and number of turns
Still, I will use core with 1mm gap and 23 turns, like all of you said, only I waiting
PCB
P.S I read somewhere about T106-26, that it has 40+10 degrees with 12 turn of 1,85mm wire (15uH) and that's totaly normal
Old 30th November 2010, 06:11 PM   #624
Pafi is offline Pafi  Hungary
Originally Posted by darkfenriz View Post
Dzony988
Why did you make a gap in a powder toroid?
Because it was told. :-)
To decrease flux change rate, therefore decrease heat. And to achieve higher saturation current.
OK, but with what supply voltage? I guess much less than 40 V.
Old 30th November 2010, 08:18 PM   #625
Originally Posted by andrewlebon View Post
hi stewin
thanking you
andrew lebon
here is my plot but i have another which is stereo and uses droper resistor instead of transistors to power the lm311 .. pls note if you are going to use +/-70vlts change the small transistors regulating power of lm 311, from(2n5401,2n5551 ) to (bd140,bd139)respectively "remember to interchange their pins"and mount them on a small sink . not to forget also to interchange the lin and hin pins of ir2110 . "i was trying to drive the amp in an opposite phase in order to bridge it easily" , never got the time to change it but i,ve managed in my another board.
thanks again andrew lebon 4 this wonderfull thread GOD bless you .
Old 1st December 2010, 07:42 AM   #626
ionutzxpo is offline ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
Dzony988
because my toroid was not an iron powder one ,looks exactlly as yours but is not iron powder i have iron powder T130-2 from micrometals I bought from here
Kits And Parts Store I do not know if I'm allowed to post
I apologize if I did not
Old 1st December 2010, 11:17 PM   #627
Ok, I'm understanding my friend
What do you suggest I use, iron powder 15turns without gap (20uH) T106-26 or 23 turns with 1mm gap (17uH) t106-26
Thanks to all
Regards, Nikola
Old 2nd December 2010, 10:36 AM   #628
Originally Posted by ionutzxpo View Post
Dzony988
Iron powder, not iron powder, what are you talking about?
Old 2nd December 2010, 11:22 AM   #629
akraj is offline akraj  Bangladesh
Hi Stewin:
Thanks for sharing the design! What is the maximum voltage can be applied and what will be output (Watt)?
Raj
Old 2nd December 2010, 11:29 AM   #630
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Perhaps it was a ferrite toroid, not iron powder? I am quite a fan of the white ferrite 'Polo Mint' gapped toroids from Ferroxcube, but wish that RS or Farnell or similar stocked them.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
