ucd 25 watts to 1200 watts using 2 mosfets
Old 28th November 2010, 07:46 PM   #601
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
Originally Posted by stewin View Post
so for a powersupply of +/- 85vlts it is safe to use the irfp360 instead of irfp260 with this circuit
For +/- 85V IRFB4229 should much better.
Old 28th November 2010, 08:38 PM   #602
stewin is offline stewin  Kenya
i've heard of irfb but not available where i am thats why i am asking of irfp260or360,460
Old 28th November 2010, 09:23 PM   #603
Pafi is offline Pafi  Hungary
Not really. I'm writing it for the 100th time like many other members: an old, high voltage MOSFET has slow body diode which makes it a bad solution in such a simple output stage. IRF360 has a Qrr of 5.6 uQ, and high channel resistance, so it's a really bad MOSFET for this circuit!
I said you should choose the LOWEST voltage rated device which meets the requirement!
Old 29th November 2010, 05:16 AM   #604
luka is offline luka  Slovenia
luka's Avatar
Qrr should really be 1/10 that
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 29th November 2010, 06:00 AM   #605
Dzony988 is offline Dzony988  Serbia
I can't find that core (mictometal iron powder 130-2) in my contry .
Can I somehow use different core, or PC core with different wire and windings, enything else.
Old 29th November 2010, 06:02 AM   #606
Ofcourse 20uH with 1uF filter, for big power amp
thanks, Nikola
Old 29th November 2010, 09:12 AM   #607
ionutzxpo is offline ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
Hi Dzony988,you can use pc core with gap (i use a stone cutter with 11krpm to make 1mm gap)
Old 29th November 2010, 04:42 PM   #608
I get it, something like that?
How many turns and thick wire for 20uH with gap of 1mm on this core.
Thanks buddy
Regards, Nikola
Old 29th November 2010, 07:04 PM   #609
yes!! that is super ok ,for 17uH 23 turns 1.2/1.5mm wire made off 12....15x0.1mm wire(home made litz)
Old 29th November 2010, 07:31 PM   #610
can that core survive if the amp supply is +/- 75vlts thanks
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
