ucd 25 watts to 1200 watts using 2 mosfets - Page 59 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 16th November 2010, 12:58 PM   #581
norazmi is offline norazmi  Malaysia
hi dacuycoy,
i`m using ferrite toroid from car amp smps, its typically material 77 i think. this is the best so far for cheap cost i can get, sometimes i get it for free from electronic shops repair here. OD its about 1.3 inch or something i made about 15-18 turns awg 16, no hot at all no noise, big sound.
regards.
Old 16th November 2010, 05:58 PM   #582
thanks norazmi, in your recent post you had mention that you used a ferrite toroid with gap, I am confuse if it is an EE toroid or circular toroid. would you mind to post a picture. i want to build this class d amp.
Dacuycoy
Old 18th November 2010, 12:31 PM   #583
Hi Dacuycoy,
There is no EE toroid or u mean EE ferrite core? I`ll take some picture of my lc filter and i`ll post here when ready.
regards.
Old 19th November 2010, 03:42 AM   #584
yes I mean EE ferrite core ... tnx can't wait for the picture
Old 23rd November 2010, 09:57 AM   #585
DJtosa2 is offline DJtosa2  Serbia
Hi guys, can this amplifier run with IRFP240, i have few peaces... thank you
And can i use L from old PS power supplay, just for testing
Thank you
Old 23rd November 2010, 10:02 AM   #586
Hi guys, can I run this amplifier with IRFP240, I have few pieces?
And can I use L from old PC power supplay, just for testing
Thanks, Regards
Old 23rd November 2010, 10:08 AM   #587
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
IRFP240 is bad fet for this kind of amp. why? slow internal diode... but probably will work in the end
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 24th November 2010, 09:16 AM   #588
qsa is offline qsa  Germany
qsa's Avatar
IRFP250N work good, a lot of high power commercial class D amps have it in output stage ... powersoft too
but does somebody know Mosfet with 300 V ratings what is working class D ?
Crest use APT50Wxxxxx in Output stage but hard to get
IRFB Mosfets have only 150 V ratings, cant use for big output power
Old 24th November 2010, 11:02 AM   #589
Pafi is offline Pafi  Hungary
Yes, mostly with tricks to avoid diode conduction! If you can avoid it, then you can use almost anything. I use IXTQ88N30 for example.
Haven't you met IRFB4227? (And bridged amplifiers?)
Old 26th November 2010, 11:26 PM   #590
Hi everyone,
Well, for reduce noice, I need good output coil, IRFP250 on output or IRF540 for low voltages. C10 of 100pF I change to 2.2nF, from pin 3 of LM311 i put 4.7nF to GND and 5.6K in serial to input. Output capacitor 1.5uF I change to 1uF if output coil is 40uH.
I have all components and tomorow I will build this amp, I plan to use PCB by Lycanlk, but on pcb I add two capacitors of 470uF near by out transistors.
Only problem are output transistors, because i dont have IRFP250, but I have IRFP240PBF, for test i hope they can work
Tell me, is this all corect about changes for reduce a noice what I wrote?
Thank you, Nikola
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
