| Class D Switching Power Amplifiers and Power D/A conversion |
#571 |
Bonjopur, I return to the topic I made progress. I simulated the LTC software schematics Attached Files IR2110_UCD.zip (421.1 KB
But that does not give me a correct answer! my questions someone does make this amplifier which simulate the schematics on LTC. Thank you for your cooperation. Greetings |
#572 |
hi quinquin07 i built the amp and it performs great ucd 25 watts to 1200 watts using 2 mosfets
#573 |
Won't let me click on attach pdf, can some one help? Thks!
some like it hot;"the biggest mistakes are made by those who make assumptions!" Graham Maynard |
#574 |
hello savu.i want to discuss with you in private if it's possible.thanks!
#575 |
is there any DC at speaker output or is this problem solved ?
#576 |
Bonjour, je vous remercie pour votre réponse, mais je copie les schémas de simuler sur "LTspiceIV de la technologie linéaire, mais je ne peut pas tourner, est-il une erreur?
Je joins les fichiers. Salutations. [Attach] 196227 [/ attach] |
#577 |
frugal-phile(tm)
#578 |
Hello, thank you for your reply, but I copy the patterns to simulate on "LTspiceIV of linear technology, but I can not rotate, is there a mistake?
I attach the files. Greetings. [Attach] 196227 [/ attach] Attached Files |
#579 |
#580 |
hi norazmi,
what type of toroid did you use? regards, Dac |
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
