ucd 25 watts to 1200 watts using 2 mosfets
Old 13th October 2010, 10:53 AM   #531
Whortless is offline Whortless  Turkey
Whortless's Avatar
Originally Posted by gogowatch View Post
How to level shift these power drivers as high side? Use ir2110, ir2113 or ir2010 again?
There are several ways of using them. It depends on your idea and need. For eg. a fast optocoupler or you can use them as a driver in UCD amp instead of discrete transistor driver etc. etc. Several ways of creating your own way to reach the aim just think and then experiment your idea. If you find the correct way it works if you did not find, you learned the wrong way that doesn't work!
Old 13th October 2010, 12:48 PM   #532
luka is offline luka  Slovenia
luka's Avatar
Depending on freq. and fets used, you could use hcpl 3180 from agilent, good up to 250kHz they say
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 13th October 2010, 01:15 PM   #533
Whortless's Avatar
Right Luka,
i did not think a newbie will try it. So i agreewith you. But, again there are several ways of using a single mosfet driver as a high side driver! You know how!
Best wishes,
Old 15th October 2010, 01:53 PM   #534
Eva is online now Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Check FAN3228 and FAN3229 gate drivers from Fairchild. They feature differential schmitt-trigger logic inputs making discrete differential level shifters (like the one used internally in IR chips) very easy to implement (with just two high voltage transistors).
Furthermore, propagation delay of these drivers is around 20ns, and maximum idle supply current is around 1mA.
I use to feel like the small child in The Emperor's New Clothes tale
Old 18th October 2010, 03:23 AM   #535
norazmi is offline norazmi  Malaysia
Default Confuse diode
hi im refer to the silk screen regarding diode 1N5817 state there but on schematic it is 1N5225, totally confuse here...
here is the attachment...
Please see on DF1 and DF2 on schematic it is 1N5817 but on silk screen file it is 1N5225??
Old 18th October 2010, 03:26 AM   #536
Default Confuse diode 2
here is the schematic....
Hope someone can make it clearly because i want to build it...
Regards.
Azmi
Old 18th October 2010, 03:29 AM   #537
its from Lycanlk design...
Thanks.
Old 18th October 2010, 09:11 AM   #538
luka's Avatar
Diodes for fets are 1n5819 or similar, as is 1n4148
and for IC supply DC1 and DD1 are zener diodes, just don't know why only 3v, but probably has something to do with LM311 speed
I FEEL SLOVENIA
Old 18th October 2010, 09:59 AM   #539
Thanks alot Luka
can i use mur120 instead of 1N5819?
Old 18th October 2010, 10:03 AM   #540
luka's Avatar
yes, I always used mur's
I FEEL SLOVENIA
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
