ucd 25 watts to 1200 watts using 2 mosfets
Old 13th September 2010, 05:57 AM   #511
savu is offline savu  Ireland
savu's Avatar
Send a message via MSN to savu
hope they come fast.... i am very curious ...
attached is almost complete pcb design made with only smd parts.
regards,
savu
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Old 18th September 2010, 11:55 PM   #512
gogowatch is offline gogowatch  Hong Kong
regards,
savu
Very compact PCB design! Very curious to know its performance.
Cheers
Old 20th September 2010, 06:15 PM   #513
powerflux is offline powerflux  Netherlands
regards,
savu
can you post the files (also for the schematic with values - that way it can't be mixed with other versions of this amplifier)?
Old 21st September 2010, 12:49 AM   #514
Dougie085 is offline Dougie085  United States
I was thinking about etching one of these. I have a bunch of PCB material I've had around for a while and want to do something with them.
I'm guessing it can't do 1200 watts with just 2 output devices? What kind of power do you guys expect/get with this smaller board?
The SMT board looks very nice indeed I just need to pick a design and get to etching it lol.
Old 21st September 2010, 12:49 PM   #515
savu's Avatar
Hello Gents,
as i speciffied the pcb is partialy finished. it misses the supply filter caps, the imput resistors and caps, the feedback loop, and the output LC filter.
when it's done i will post complete pcb design with part values.
regards,
savu
1'st rule of chess:
Old 22nd September 2010, 01:06 AM   #516
Default A bit faster level shifter
Originally Posted by Tekko View Post
Heres a simulation of what im gonna try when the MAX913's arrives.
Hello Tekko,
If you add a 10pF cap parallel to R3 or R15, you will get a bit faster level shift.
Here is the sim,
Old 22nd September 2010, 01:09 AM   #517
Hello Gents,
regards,
savu
I think I may try your board once it's finished.
Old 29th September 2010, 05:41 PM   #518
lycanlk is offline lycanlk  Sri Lanka
Default I've got a problem with Ejtagle UCD when driving 12 inch woofer..
I've got a chance to drive 12 inch JBL speaker GT01214 with my UCD.. I used the following lowpass filter but the amp could not drive the speaker after a certain level that It produces clipping noise for drum foot.. I wish thats before clipping level. but when I use this filter with a class AB amp (DX standard by Carlos), the woofer drives well without any clipping noise.. also can volume more than my UCD to drive the woofer well enough and have a good output power (good bass). My questions is that its because of class AB clipping noise is not audible ?? or if not whats wrong with my UCD over others ?? I dont have a scope to measure but theres a huge difference between those 2 amps.. used the same supply for both +/- 50v. that is true I increase the gain of the low pass filter to fit my input source... and I can assure that its not the issue because of both the amps give almost equal output at same level of input.. some professional advice is needed.
Thanks in advance and best regards,
Lycanlk
Old 8th October 2010, 09:54 AM   #519
stewin is offline stewin  Kenya
hi guys if mosfets are paralled together like the below scheme but using irfp 250 with ucd 25 - 1200 scheme can it increase power instead of using irf 4227 cause of the availability issues.
Old 8th October 2010, 10:18 AM   #520
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Originally Posted by gogowatch View Post
Hello Tekko,
Here is the sim,
And two more capacitors are added directly from comparator outputs to HIN and LIN gate driver inputs, it's even faster. The optimum capacitance value may be lower than 10pf. But this requires clean supply rails, any substantial Mhz ripple on the negative rail WRT ground will make it unreliable, and your PCB layouts are likely to produce plenty of that.
I use to feel like the small child in The Emperor's New Clothes tale
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
