Go Back   Home > Forums > Amplifiers > Class D
Old 28th August 2010, 07:17 AM   #481
I bought a Lepai LP-2020 to see if that really is as prone to break as it appears here, i already modified a laptop psu for it, lowered the voltage from 19V to 13V.
As for the prototype, its not the design thats basically wrong, i believe the heatsink isent flat so that part of the fets dident have proper contact with the heatsink.
Also the gate resistors were 22 ohms which i think is alittle high for 400+ kHz operation and the gate diodes were 1N4148 which dident have anywhwere near the current ratings needed for a fast discharge, so im not all that suprised it failed.
Before i left it to play music i did a destructive test, i hooked it to a 4.6 ohm dummyload and turned the bass all the way up on a mp3 player and turned the volume all the way up, this the amp survived and no clipping was observed.
The gate resistors will be lowered to 10 ohms and the gate diodes replaced with 1A UF160's, also the heatsink will be replaced with one that have a proper surface and i will also mount the board properly.
If this still causes it to blow up, well then i'll abandon the design and try something else when the MAX913's arrives.
Old 28th August 2010, 11:45 PM   #482
opor is offline opor  Thailand
Originally Posted by Baldin View Post
Ok. Changed a few components, and skipped the big capacitor in the input ...
Now it starts up every time, but only with a load (speaker or 8 ohm resistor).
Switching freq is 235 kHz
Because I had to remove the big cap ther is 0,6 V DC on the output .... need to find a solution ... any suggestions??
Also need ot find a way to make it start without the load ...
Otherwise it seems quite good for a breadboard circuit
And I think it is an improvement over the original ........
Hi Baldin,
Refer to your schematic ,is there any noise problem still?
Old 29th August 2010, 09:27 AM   #483
Baldin is online now Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Hi opor
There will always be noise when building up a class-d amp on a breadboard, with long leads hanging out everywhere ...... but that will be dramatically reduced when you get it down on a good PCB .....
And whether this circuit has more noise problems than others .... is a bit harder to tell before you get it to the PCB ... but I would think not
As I said I think it's an improvement over the original circuit.
I will not take it further myself, as I'm still improving on my own amp, (not UcD) .....
Best regards Baldin
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 29th August 2010, 09:36 AM   #484
savu is offline savu  Romania
savu's Avatar
Send a message via MSN to savu Send a message via Yahoo to savu
Hello Baldin,
off topic:
does BCA (crown patent) apply to selfoscilating class d amps? or just to their amp?
regards,
savu
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Old 29th August 2010, 09:47 AM   #485
Baldin's Avatar
Yes I think you could make it work for self oscillating designs as well .... the question is whether you would want to ..... unless you are going to make proff amps, I don´t think full bridge designs in general are worth the extra effort ...
Old 29th August 2010, 09:52 AM   #486
savu's Avatar
hi baldin,
off topic:
I want to make a class d amp with very low propagation delay, full bridge on single supply with all SMD parts. i have the thing running in LTspice but i want to be sure that i do not step over anybodies toes. Especially Crown since i want to make it to run without dead time because the SMD transistors will have to dissipate very low power, so i have to use something like the BCA method.
regards,
savu
1'st rule of chess:
Old 31st August 2010, 04:27 AM   #487
I am wondering what is considered good RF suppression from a digital amplifier.
I designed a three channel class d running +- 42 volts. 4 layer board
It is mounted 3 inches from the (Mechanical ganged capacitor) tuner section in a Pioneer reciever because no other space was available. Eva appears to be very knowledgeable on D amps
The AM works fine up to 1200Khz (D amp frequency)
The FM has noise in stereo mode.
My oscilloscope is an old 10mhz model, but shows no ringing.
Old 31st August 2010, 05:37 AM   #488
Because the ringing is in the 50-100MHz range, way too fast for an old 10-25MHz scope.
This design in its original form sucks, its very bad! Im working on improving it alittle.
Old 31st August 2010, 06:27 AM   #489
savu's Avatar
Teko,
how high did you manage to get the carier frequency of the original schematic?
because i only got it arround 225Khz and this using a zobel.
regards,
savu
1'st rule of chess:
Old 31st August 2010, 02:08 PM   #490
lycanlk is offline lycanlk  Sri Lanka
Off topoic:
I have a same kind of question about UCD. what is the patent lies on UCD..?? is it for as a whole concept? or the oscillation/self oscillation? or a specific design??
It is said 'universal class D'. which means any class D goes under that patent or what? if not can anybody give me a live example(a class D amp) that doesn't go under UCD patent?.. I'm so confused.. with these techniques and patents when learning and designing class D amps.
wish if Eva could answer for this but any helping post will be appreciated
Thanks in advance !
best regards,
Lycanlk
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2013 diyAudio
