ucd 25 watts to 1200 watts using 2 mosfets
Old 5th December 2017, 11:26 AM   #4651
kees52 is offline kees52  Netherlands
I have try some things with a discrete comparator and a IR2011 and lead lag and poles to get low distortions, however the IR2011 model for LTspice give a strange square wave and using dead time give more shoot through then without, strange.
I did put this here because here are some more tryouts and learning is always oke.
regards
Old 8th December 2017, 02:31 AM   #4652
kartino is offline kartino  Indonesia
kartino's Avatar
Originally Posted by stewin View Post
o.k thanks katrino, i will give it a try
This is my sigma delta in BTL
YouTube
Old 8th December 2017, 02:41 AM   #4653
kartino's Avatar
Anyway why don't you go for fullbridge.
Fullbridge is better, very very stable and robust. I have both UcD and sigma delta. My sigma delta is fullbridge, supplied up to 115Vdc very stable (and can be more).
BTL problem is stability. Higher supply volt will be more issue.
Old 8th December 2017, 01:18 PM   #4654
toreto009 is offline toreto009  Russian Federation
do you have a circuit and pcb your amplifier fullbridge?I want to build it.
Old 9th December 2017, 04:41 AM   #4655
Diymed is offline Diymed
YouTube
this is my class d 1u work in btl . parts is inside lol
Old 10th December 2017, 06:00 AM   #4656
kartino's Avatar
What do you mean??
Old 10th December 2017, 06:01 AM   #4657
kartino's Avatar
Find my thread.
I give only schematic.
Old 10th December 2017, 10:22 AM   #4658
I did sim btl version, it give strange outcomes, need a 30 khz higher carrier on one side. better is indeed a full bridge, no need for sync.
Last picture you see the voltage is strange but the current looks oke with very low distortion, not yet dead time implemented tough.
regards
Old 28th December 2017, 11:10 AM   #4659
Find my thread.
Hello Mr. Kartino. What do I need to change in the circuit to start with a power supply of 65-70 volts?
Old 31st December 2017, 05:26 AM   #4660
Dinithm is offline Dinithm  Sri Lanka
new desing 300W+300W Rms true deep bass
+-56V supply voltage
40V peak to peak output voltage @ 2ohms
(28Vrms @ 2ohms /actual 400W)
2xIRS2092 4xIRFS4227
TDA7416 audio prosesor/stm32f103 controller
600w class d irs2092 - YouTube
YouTube
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
