ucd 25 watts to 1200 watts using 2 mosfets
Old 8th November 2017, 05:19 PM   #4621
stewin is offline stewin  Kenya
hi all
i am back with my issues about sigma delta irs900d .
i have tried to bridge two irs 900d without success , they always end up latching or producing noise and drawing alot of current.
i increased the output inductance to 120uh (it improved the situation but did did not help)
i added 80uh inductance to each power rail of each channel both +/- rails also (it improved the situation but did did not help)
the major issue ,is that when you disconnect the load from the amplifier the ,amp suddenly becomes unstable and draws alot of current like a short circuit , and the output fets heat up
Old 8th November 2017, 05:54 PM   #4622
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
Hi , show the exact schematics.
Unstable - it generates on the resonanse frequency of the output filter ?
Old 8th November 2017, 07:29 PM   #4623
just the normal irs900d circuit by detex audio . output fets are irfp250 .supply voltage +/-38v
Old 16th November 2017, 10:19 PM   #4624
protech1104 is offline protech1104  Tunisia
protech1104's Avatar
hi all
in steréo mode your amplifier work good? if yes you must have a low pass filter at aop used for the bridge.
and dont run 2amplifier at same frequency
Old 17th November 2017, 10:17 AM   #4625
kees52 is offline kees52  Netherlands
Did you use 180 degree shift? otherwise you get big trouble who looks a like as you already have explane.
regards
Old 18th November 2017, 04:23 PM   #4626
meaning one to be at 430khz and the other at 400khz ??
Old 19th November 2017, 04:29 AM   #4627
KimeraTeam is offline KimeraTeam
how to change frequency to 250KhzClick the image to open in full size. suply +-50Vdc
Old 28th November 2017, 06:19 PM   #4628
this circuit is not stable. use apex d200 version is good and simple. and use external 12v supply for driver regulated for less heat supply transistor
Old 28th November 2017, 06:22 PM   #4629
yes. but also irs 900 is not stable. the best is apex d200 or macky srm450 is the same
Old 28th November 2017, 06:24 PM   #4630
i have a d200 that work without problem for 5 years now
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
