ucd 25 watts to 1200 watts using 2 mosfets
Old 20th August 2010, 12:03 AM   #381
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
It's by far not as bad as you imagine. And his imagination tells a lot about how things are going in life for somebody...
The protection that tripped was in the power supply and involves a current sense transformer with 200 turns and inherent antenna properties. Ironically, this transformer is working at mains frequency, it's a linear circuit involving op-amps and a PIC. It's calling for a couple of ferrite beads and caps to avoid rectification of ambient RF in the input LTP of a bipolar op-amp.
Protection against wrong oscillation modes is very useful as the product ages. Imagine the result of an open feedback resistor or a cold joint somewhere. Bang! or immediate shutdown.
btw: No, it does not make funny noises unless the phone is placed crazy close to the modulator
btw2: That's without an enclosure, bare pcbs on a wood bench
I use to feel like the small child in The Emperor's New Clothes tale
Old 20th August 2010, 12:56 PM   #382
Tekko is offline Tekko
Banned
Today i built a little circuit that provides a delayed turnon to let the caps charge before the amp goes active.
Heres a short vid of the cir in action:
YouTube - Delayed turnon circuit
Old 20th August 2010, 01:13 PM   #383
luka is offline luka  Slovenia
luka's Avatar
now that is great, starting to be a good amp, keep at it
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 20th August 2010, 02:09 PM   #384
qsa is offline qsa  Germany
qsa's Avatar
can you provide schematic for delay turn on ?
Old 20th August 2010, 02:27 PM   #385
Banned
This is the schematic for the delayed poweron board:
Old 20th August 2010, 08:04 PM   #386
Banned
It have turned out im still below 200kHz, had moved a knob on the scope without knowing it, so that it looked like the frequency had increased to 300kHz.
And now i noticed there were too many resistors in the input part so when i removed those i actually did climb to 250kHz, and it sounds like it improved ther sonics as well.
Old 20th August 2010, 08:23 PM   #387
AP2 is offline AP2  Italy
Banned
Hi tekko,
I'm curious to know ... tr1 puts down pin SD IR210? If so, there was no need to use transformer IC + bjet +parts
Old 20th August 2010, 08:38 PM   #388
Banned
AP2, i used the enable/disable in the current source like in the philips ucd schematic: http://www.nxp.com/documents/user_manual/UM10155.pdf
pad 3 and 4 in my schematic, tho i guess using the sd pin on the IR2010 would yield similar results, i chose what i chose because i dident feel like digging up the ground plane around the SD pin.
And here are two new pics of the updated startup delay:
Amp in standby, no oscillation:
Amp active:
The white led was supposed to be yellow, picked the wrong bag.
Old 20th August 2010, 10:37 PM   #389
Banned
Hi
well, maybe...this running for
Old 20th August 2010, 10:52 PM   #390
Banned
well i use not only a delayed poweron but a more or less instant power off rather than having it keep oscillating as the psu drains out with a pop of squeek as the end result.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
