ucd 25 watts to 1200 watts using 2 mosfets
Old 18th September 2013, 12:39 PM   #3701
opor is offline opor  Thailand
Hi Lorylaci,
Thank you for your advice. But what is fsw of this circuit with 4.7nf feedback , 50uh coil and 0.47uF LC filter.
BR
Opor
Old 19th September 2013, 06:34 AM   #3702
lorylaci is offline lorylaci  Hungary
lorylaci's Avatar
Send a message via MSN to lorylaci
Originally Posted by opor View Post
Hi Lorylaci,
BR
Opor
I CANNOT TELL! (Very few can!)
As I said: swtiching frequency is a function of:
- duty cycle
- propagartion delay
- feedback network
- LC filter
- ETC!!!
Analytical determinition by values is extremely difficoult, simulation or mearsurement is possible.
First of all try to undesrtand swithcing basics, like self-oscillation. Its not a clocked (triangle wave comparator) class-D. If its to much for you, pick up books (and application notes) and LEARN!
Olyan nem volt még, hogy ne lett volna valahogy
Old 19th September 2013, 06:40 AM   #3703
lorylaci's Avatar
Originally Posted by pergo View Post
was only a test for the control board.
I will never use IRF640N or similar fets for a class D, but i had them in stock.
The test was focused on noise, too.
Anyway, i prefer IRS20957 instead of shifter+splitter+IR2x10. Less components, more safety, more performance.
IRS20957 is a good one, it has definetly less propagation delay (much faster) than the dsicrete levelshifter+IR2110. It has also lossless current sensing option (measureing voltage drop at FET's Rdson while FET is on).
However it is harder to get, and more expensive (twice or tripe the price of IR2110).
If you says your s***y matrix board is so good with IRF640N, then why you say you never is it?
Of course I understand, I prefer testing with cheap FETs on stock too, but later I realized that schamtic and layout should be tuned for the actual setup, actual FETs.
Also think about using full-bridge. With cheaper FETs (half the voltage rating), you can cut back losses down to half!
Old 19th September 2013, 10:56 AM   #3704
pergo is offline pergo  Italy
pergo's Avatar
Mouser sell PDIP IR2110 at 3.45€ and IR2010 at 3.75€. Soic version at 2.71€ and 3.87€.
IRS20957 at 2.99€
Not bad.
Nessuno può farvi sentire inferiori senza il vostro consenso
Mr.P Electronics
Old 20th September 2013, 09:06 AM   #3705
lorylaci's Avatar
IRS20957 at 2.99€
Not bad.
Prices depend extremely. IR2110 is and "old" one, it's been around in PSUs for a long, so you can get it almost everywhere. In my local shops it costs 1,5-2,5 Eur PDIP (depending on order size).
For example, In Hungary IRS20957 can be only bought from Farnell, at about 4 eur (depentind on quantity).
Think of stewin in Kenya. Farnell ships there, but at a great price, plus customs.
Old 23rd September 2013, 05:10 AM   #3706
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default D CLASS SCHEMATIC
File Type: jpg 1373454_10200354189239736_685407365_n.jpg (87.6 KB, 2002 views)
"It's Better to try and fail than to never know and always wonder"
Old 24th September 2013, 05:34 AM   #3707
lorylaci's Avatar
Originally Posted by andrewlebon View Post
Its not an UcD amp. Its a simple triangle generator ful-bridge class-D amp. Its not reccomended for quality design, since it has no feedback (high THD, low damping factor, no PSRR).
Old 26th September 2013, 01:09 PM   #3708
mkuczma is offline mkuczma
Hi lorylaci, I want to build iraudamp7 with my own pcb and I have a question:
You show your PCB with big ground plane on a double sided board but in IR note AN-1138 is wrote: The irs2092 does not accept single ground plane. And there is a picture show a 3 plane: analog ground, reference ground and power ground. What is your opinion about it?
Old 28th September 2013, 02:33 PM   #3709
Cresnet is offline Cresnet  Jordan
my amplifier shows 192KHz at output, sine wave
even when I feed it with sine wave 1KHZ, still I get 192KHz at speaker output
any advice?
Old 28th September 2013, 05:23 PM   #3710
Default detex smps and irs1500 stereo pcb
stereo d class amp kit
File Type: jpg 1381404_230414243781690_82579209_n.jpg (110.1 KB, 1796 views)
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
