ucd 25 watts to 1200 watts using 2 mosfets
Old 28th June 2013, 10:48 AM   #3571
Tekko is offline Tekko
Banned
If it doesent selfstart it means the poles and zeros are not properly placed.
Old 5th July 2013, 03:47 PM   #3572
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default SONY D CLASS
Hello
greetings anyone tried this schematic
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 8th July 2013, 05:08 PM   #3573
wattaniya is offline wattaniya
pls anybody tell me is this core suitable for class d amps,
outer dm-2 inch
inner dm-1.25 inch
Old 8th July 2013, 09:49 PM   #3574
stewin is offline stewin  Kenya
Originally Posted by andrewlebon View Post
Hello
warm regards
andrew lebon
try the forum below in diy audio
GZPA Class D 4000W with IRFP264
Old 11th July 2013, 06:44 PM   #3575
redmx is offline redmx  United States
Originally Posted by SERGIODS View Post
Hello Tacato have the complete PCB, already armed beam.
PS: It looks great.
hi I'm no longer with the original project ucd tacatomon this amplier mentioned is very unstable and much emi also has lots of background noise. I'm dealing with delta sigma is excellent and does background noise , greetings to the forum
Old 20th July 2013, 04:27 PM   #3576
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
Default ready in stock
ready in stock IRFB4227 and IRFP90N20D ... any one interested to buy ... then PM me.. thank u
Old 20th July 2013, 04:33 PM   #3577
CDJKuznec is offline CDJKuznec  Russian Federation
CDJKuznec's Avatar
Hi exflaco. I from Russia. Excuse me for my bad English. Here ucd 25 watts to 1200 watts using 2 mosfets
in the 2034th post you told "Irvinejay tri-l have 2 verssion 110 and 220v direct ,only rectifier and capacitor no power suply".
Give me please a payment with face (PCB, lay) values on 220 volts. I will need use it on 220 volts of supply.
In advance I thank you!
Old 20th July 2013, 04:51 PM   #3578
exflaco is offline exflaco  Armenia
CDJKuznec wait to monday y have information in other pc no problem y share ,you neet a aislating signal transformer and its only for powered boxs its dangerous to use in power amp standard rack measure, the output to 220v direct ,no smps could kill you
Old 20th July 2013, 05:02 PM   #3579
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
Originally Posted by CDJKuznec View Post
I from Russia.
Питание напрямую от сети 220Вольт - ОПАСНО ! и фактически неприменимо!
If you don't know english enough , ask in russian - http://forum.cxem.net/index.php?showforum=122
Old 21st July 2013, 03:50 PM   #3580
CDJKuznec's Avatar
I know that the direct use of 220v is very dangerous, and I will use a transformer for galvanic isolation. By lowering the voltage to + -95, obtained large size transformer. So I want to use the 220 ​​for the card, but do not know which components of change for the strain.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
