ucd 25 watts to 1200 watts using 2 mosfets
Old 24th June 2013, 12:26 PM   #3561
ionutzxpo is offline ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
Hi Tekko,where did you get those aluminium blocks?
Iacob Ionut
Old 24th June 2013, 12:43 PM   #3562
Tekko is offline Tekko
Banned
The heatsinks ? I cut up a heatsink from a ATX PSU.
Old 24th June 2013, 01:05 PM   #3563
yup the heatsink
Iacob Ionut
Old 25th June 2013, 07:17 PM   #3564
stewin is offline stewin  Kenya
hi all good news for recycling ferrite cores
>>>>> diysmps <<<<<<<<
Old 27th June 2013, 10:36 AM   #3565
ravpreet420 is offline ravpreet420
irs 1500 not working perfect....when volume low then green led off state ,when green led glowing with volume(sound) level.when low volume then amp does not occilate.when volume high level(after 20%) then green led glow with full light & sound is clear .at low volume amp does not occilate....
all pcb connection, track is clear & right
Old 27th June 2013, 03:57 PM   #3566
kirubakaran is offline kirubakaran  India
hi,
greeting,
ravpreet, irs1500 is delta sigma class d so this amp want input signal to start osilation, once start osilation amp working perfect.
Old 27th June 2013, 11:43 PM   #3567
JLesterP is offline JLesterP  Philippines
IRAUDAMP1 has an extra circuit to start the oscillation even without input signal. You might want it to include in your IRS1500 layout.
amplifier PCBs and modules
Old 28th June 2013, 01:46 AM   #3568
SERGIODS is offline SERGIODS  Peru
Originally Posted by tacatomon View Post
Hello!
I lost some time and among many messages ... What happened to the onset UCD design theme?
Still working with the design and it has never failed one. I see that there have been other diagrams and do not work quite right.
It is something to adjust here and there ... The design is good and can be very reliable and respectable power.
Greetings!
Hello Tacato have the complete PCB, already armed beam.
PS: It looks great.
Old 28th June 2013, 08:34 AM   #3569
Originally Posted by kirubakaran View Post
hi,
greeting,
i know sir but main problem at low volume ,
everytime increase volume then amp start normal
Old 28th June 2013, 08:45 AM   #3570
how many millivolts of ac input signal is required to start the oscillation?
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
