ucd 25 watts to 1200 watts using 2 mosfets
Old 14th May 2013, 11:20 PM   #3511
NMOS is offline NMOS  Germany
NMOS's Avatar
Have make IRS4K5 but big Problem, not working !
NE555 and LM311 very hot after 1 minte
IR2110 - NXP HEF4049 or Texas Instruments CD4049 - TL 071 cold and have 12V bzw. 5V rail
Red Protect LED is on and IRS4K5 not work
does this PCB working or is it fake ?
I have replace all, ICs, Mosfets everytime same fault
Does somebody have solution ?
File Type: pdf IRS_4500 with Totem Pole Buffer mosfet driver.pdf (398.9 KB, 816 views)
Old 15th May 2013, 06:18 AM   #3512
stewin is offline stewin  Kenya
please check your board thoroughly because i have made three of them and they work . except you have to do a lot of debugging because the pcb traces are very close.
Old 15th May 2013, 08:00 AM   #3513
NMOS's Avatar
Im using mosfet IRF640n can you check my pic and green IRS4K5 pcb file is it the same like yours ?
or can you send me your file,
phoonpool@googlemail.com
then I can check by myself, I dont like spend time if its a fake
best regards
Old 15th May 2013, 03:02 PM   #3514
fra is offline fra  Slovenia
hay
The diode 1n4148 near 4049 si in the wrong direction.
Old 16th May 2013, 04:31 PM   #3515
best regards
hi nmos please change the diode fra is talking about. i made the one using the to 247 package i used irfp260n x 3pairs gate resistors were 100ohms
Old 16th May 2013, 05:01 PM   #3516
best regards
Old 16th May 2013, 05:21 PM   #3517
NMOS's Avatar
Ok thanks have change diode 1N4148 look pics
then have check my board all look ok
Then After connect with Rail Ics and Mosfets are cold
Green Led flash short time and speaker make plopp after connect with rail.
Amplifier have no DC at outpurt all looks ok,
After disconnect Rail green Led flashs about 3 seconds and speaker make plopp plopp plopp plopp
But Im worry now,... no music comes out.
have replace all ICs but same like before, no music comes out
Then have amp connect with PC Soundcard, with maximum Volume output from Soundcard I get distortion noise
I dont know what can I do to get music?
I cant see fault in Board, any idea to solve problem, have upload pics from Board
Old 16th May 2013, 08:22 PM   #3518
check connections and all tranzistor.
what kind diode did you inserted instead mur160?
Old 16th May 2013, 08:55 PM   #3519
NMOS's Avatar
Have use Diode UF4004 instead of MUR160
ok will check board tomorrow again
Old 17th May 2013, 05:34 AM   #3520
hi nmos i still insist you go through all the pcb traces again . i faced the same issues because pcb traces are so close together. i had to recheck many times but the pcbs i made all worked after many rechecking and clearing the tracks.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
