ucd 25 watts to 1200 watts using 2 mosfets - Page 349 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 2nd May 2013, 06:30 AM   #3481
redmx is offline redmx  United States
Default Schematics ??
hi all I have doubts why diagrams removed
if all this, now this amplifier with sigma delta modulator is basically the work of international rectifier IRAUD1 and pag.IRF is available in this forum is to discuss and learn and then teach because it removed the schematics and PCB artwork? ?
greetings to all ...if the moderator permits desire iraud1 put the diagram and leave here as a reference in fact heard super good
Old 2nd May 2013, 04:40 PM   #3482
andrewlebon's Avatar
Pira CZ Compressor/Limiter/Clipper for FM broadcasting
sameerx1 LINK to pcb
"It's Better to try and fail than to never know and always wonder"
Old 2nd May 2013, 04:51 PM   #3483
Was ist ein OTA? (Dynamiklimiter mit OTA LM13700, LM13600, CA3080, transconductance-amplifier, agc-amplifier)
link to EXFLACO schematic Triell limiter
Old 2nd May 2013, 05:36 PM   #3484
Originally Posted by andrewlebon View Post
one more smps completed
warm regards
andrew lebon
hi andrew
do ee16 or 19 have gap in the middle legs.pc cores have gap in midde legs i got cores without gap too.
did you use 15swg single solid wire or srands.
i have 23 swg wire thinking of paralling 5 in primary is it ok.
regards
thanks
Old 3rd May 2013, 02:09 AM   #3485
Hi Ravs
greetings EE19 core use one with gap and use 5 parallel strands 23 swg
warm regards
andrew lebon
Old 3rd May 2013, 04:21 AM   #3486
Default Audio Limiter
Audio Limiter for class d amplifier
http://www.facebook.com/sameer.audio
Old 3rd May 2013, 04:43 AM   #3487
stewin is offline stewin  Kenya
hi sameer please post the pcb files and the schema of your 2.5k smps
Old 3rd May 2013, 09:15 AM   #3488
exflaco is offline exflaco  Armenia
Another easy and cheap limiter
Old 3rd May 2013, 09:26 AM   #3489
Yes no problem to adjust 1vrms friend look the link to german page
Old 3rd May 2013, 01:02 PM   #3490
Banned
I've cobbled together a PSU/modulator board to go along with the power module boards.
It may not look too impressive but the seemingly long traces only handle TTL DC signals (enable/mute) so it shouldent be an issue.
This module uses a LM393 and is thus designed to be used with two power modules to form a full stereo amplifier, however i am not sure this will work as the two halves of the LM393 may interfer with each other, causing problems such as noise.
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
