ucd 25 watts to 1200 watts using 2 mosfets
Old 28th April 2013, 05:18 PM   #3471
sameer x1 is offline sameer x1  India
Default class d 6000w
My class D stereo amplifier 6000 W rms 2 ohm with smps supply
Old 28th April 2013, 05:39 PM   #3472
akraj is offline akraj  Bangladesh
Do you sale those amps?
Old 28th April 2013, 05:49 PM   #3473
Insomnia is offline Insomnia
how about protections DC OVP HOPS
DC crowbar
Then Balanced Input? limter
Old 28th April 2013, 07:54 PM   #3474
stewin is offline stewin  Kenya
hi sameer pls post the pcb files of your smps
Old 29th April 2013, 05:35 AM   #3475
rakesh_sharma23 is offline rakesh_sharma23  India
rakesh_sharma23's Avatar
Hi.
Send a message regarding VU meter.
Old 29th April 2013, 06:34 AM   #3476
>>>>what is your switching frequency in your smps?
>>>>are you using in the 6kwts class d irfp250n as outputs?
>>>>and at what voltage is the class d operating in?
Old 29th April 2013, 10:03 AM   #3477
jcoelhogsia is offline jcoelhogsia  Brazil
jcoelhogsia's Avatar
VUM.wmv - YouTube
Old 29th April 2013, 10:07 AM   #3478
VU metr :: S-O
Old 30th April 2013, 06:02 AM   #3479
redmx is offline redmx  United States
Default good job highand
good job highand this amp seems good when power is not important but the quality and the cost to own environmental speakers or small
only one question which component is SD
I will try to make this amplifier
soon will expose an amplifier with almost perfect driver
dt adjustable 0.4 ns to 1us
4 amp output + Input to output isolation for low noise need not shift lever
750v works more
8MHz operation until
seems like a dream for Class D amplifiers
greetings and good wishes to all
Old 2nd May 2013, 12:43 AM   #3480
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Andrew your request
Work very well on class d
Hi Exflaco
greetings schematic from post # 2430 can output voltage be adjusted to 1 volt RMS approx
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
