ucd 25 watts to 1200 watts using 2 mosfets - Page 343 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 9th April 2013, 09:06 AM   #3421
Banned
Delta sigma however requires high order modulators in order to push noise out of the audio band which calls for complex circuits of several comparators and integrators in series, so for simplicitys sake i prefer UcD over delta sigma.
Basically post filter feedback from what i've seen over the years on this forum is the way to go for self oscillating class d amplifiers, wheres clocked designs is a waste of time.
Old 9th April 2013, 01:40 PM   #3422
Send a message via Yahoo to ionutzxpo
Selfoscilating and pre+postfilter with 8th order output filter is gold (for me).
Iacob Ionut
Old 10th April 2013, 09:09 PM   #3423
well as on the board or as a diagram? I apologize for machine translation.
правильно как на плате или как на схеме ? Прошу прощения за машинный перевод.
Old 11th April 2013, 02:34 PM   #3424
manojtm is offline manojtm  India
manojtm's Avatar
Hi Tekko,
You can add external freq. to sigma-delta design if you want, still it is low noise one
MANOJ
Old 11th April 2013, 03:04 PM   #3425
Banned
From what i read, post filter feedback has advantages above pre filter feedback such as beeing load invariable, ie the switching frequency is defined, not 200kHz for a 2 ohm load and 600kHz with a 8 ohm load and 400kHz with a 4 ohm load and such like pre filter feedback topologies. As well as beeing flat over the 20-20000Hz audio band instead of only beeing flat at the designed load impedance wheres on 8 ohms freq response peaks at higher frequencies and ohm 2 ohm load freq response starts drooping at a lower frequency than on 4 ohms.
Atleast this is what i read, assuming its not just marketing bullsh*t by Hypex to boast their UcD sales.
Maybe Bruno himself has some input on this ?
Old 11th April 2013, 03:25 PM   #3426
manojtm's Avatar
Hi Tekko,
I think pre filter feedback is not a NF its only for freq. locking for fsw and it is not affected with audio band and if need NF(Negative Feedback) use post filter feedback.
MANOJ
Old 11th April 2013, 03:50 PM   #3427
Banned
I take it you do not like the UcD topology that relies on post filter feedback for the self oscillation itself.
Old 15th April 2013, 01:58 AM   #3428
andrewlebon's Avatar
Default IRS DCLASS
Sameerx1 dclass finally being packed with smps supply
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 15th April 2013, 12:09 PM   #3429
Default My all amplifiers
My all amplifiers tested successfully on full night of 14 april
DSCN4212 - YouTube
warm regards
Sameerx1
Old 15th April 2013, 02:27 PM   #3430
DSCN4212 - YouTube
warm regards
Sameerx1
Thank you.
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright 1999-2017 diyAudio
