ucd 25 watts to 1200 watts using 2 mosfets
Old 4th April 2013, 12:07 PM   #3411
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Hi Exflaco
greetings totem is MPSA42 MPSA56 isnt mpsa 42 complementary to mpsa 92
warm regards
andrew lebon FULL FILES WILL BE SHARED
"It's Better to try and fail than to never know and always wonder"
Old 4th April 2013, 07:28 PM   #3412
ChocoHolic is offline ChocoHolic  Germany
Originally Posted by norazmi View Post
current rating its depend what type of mosfet you are using, 20-30 amp is enough.
...mostly true.
In classD the limitation often is not given by the current rating, but more by the switching losses and Rth of the MosFet.
Consequently a MosFet with good body diode and low Rth, but not impressive current rating, can easily outperform (also in terms of amp power) a stone age monster with poor body diode.
The higher your fs, the more this will apply.
Old 5th April 2013, 08:11 AM   #3413
Tekko is offline Tekko
Banned
I've put together a "Universal Power Module (UPM) that supports both pre and post filter feedback, as well as clocked modulators.
Bottom layer: http://i.imgur.com/IRWpUxu.png
Top layer: http://i.imgur.com/rnssSzN.png
This is however just a preliminary layout that may change at any time.
Old 7th April 2013, 12:34 PM   #3414
JLesterP is offline JLesterP  Philippines
Anyone tried CD4069 for comparator? I want to save space for the pcb so I'll gonna try it instead of CD4049
Old 7th April 2013, 12:39 PM   #3415
Banned
There was once a class d amplifier posted in this section that only had 4000 series or 74 series logic ics in the frontend, the OP was named nitrate and the amp was called madamp and it was a basic delta sigma approach.
Old 7th April 2013, 07:48 PM   #3416
luizcpimenta is offline luizcpimenta  Brazil
Originally Posted by manojtm View Post
Hi Stewin,
can you tell me the air gap of ETD49 and EE19. A=?? for 95V load
Manoj
Hi sweet,
I will give you the sprint layout file for AUD600 & Power AUD600
Manoj
Hi Manoj.
Please send me that file too.
luizcpimenta@gmail.com
Thank you.
Old 7th April 2013, 11:37 PM   #3417
stewin is offline stewin  Kenya
hi all i am making at least a supply to reach 2.5 kwt with o.c protection just about to finish . any ideas would be highly appreciated
Old 8th April 2013, 02:27 PM   #3418
ade7susanto is offline ade7susanto
Originally Posted by IRSound View Post
Hi guys..
so I've just finished IRS1500..but there is also a problem
please watch this video :
Class-D IRSD1K5 - No & Low Level input Problem - YouTube
when i turn on power supply..after s short delay , speaker connected to amp's out. as you can hear in video , there is a noise available at output. (input volume = 0) and when i increase volume up to 4~5%, a really bad audio signal become appear. also the active led indicator isn't bright constantly.
when i increase the volume (about 7~8 %) the amp start to oscillate and those problem solved.
guys please help me. anyone have similar problems ?
IRSound
hi IRSound ,i know your problem ,
change you IC CD4049 with other manufacture
i have same problem like you
and result are ok change IC CD4049 with ST manufacture ,before TI manufacture.
my irs can work at minimal 15 volt supply with out change RSS (6,8k)
regards,
Reno
Old 8th April 2013, 07:50 PM   #3419
to add on the above . i had problems with irs4k5 outputs were heating , once i changed the cd4049 . everything was o.k and outputs stopped heating.
Old 9th April 2013, 09:31 AM   #3420
manojtm is offline manojtm  India
manojtm's Avatar
Hi Tekko,
Why you call madamp???
I think Delta-Sigma design was good one compare with other self oscillated design.
Low noise,No hum and clear sound.
MANOJ
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
