ucd 25 watts to 1200 watts using 2 mosfets
Old 14th August 2010, 01:41 PM   #331
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Default Works but ....
Ok. Changed a few components, and skipped the big capacitor in the input ...
Now it starts up every time, but only with a load (speaker or 8 ohm resistor).
Switching freq is 235 kHz
Because I had to remove the big cap ther is 0,6 V DC on the output .... need to find a solution ... any suggestions??
Also need ot find a way to make it start without the load ...
Otherwise it seems quite good for a breadboard circuit
And I think it is an improvement over the original ........
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 14th August 2010, 02:48 PM   #332
Tekko is offline Tekko
Banned
Its ALIVE!!!
YouTube - Homemade class d amplifier
Old 14th August 2010, 04:48 PM   #333
Baldin's Avatar
Originally Posted by Tekko View Post
Super
So, what was wrong?
Does it start every time?
....... also without load?
What is the switching freq?
Old 14th August 2010, 04:56 PM   #334
lycanlk is offline lycanlk  Sri Lanka
congratulations !
Old 14th August 2010, 04:57 PM   #335
luka is offline luka  Slovenia
luka's Avatar
x2
Tell me something OT, how did you get TI class d eval board and how much was it?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 14th August 2010, 05:04 PM   #336
Baldin,
Mine start smoothly with or without any load ! Sorry I cant help you technically.. I'm a guy building amps with very few of tools. but I think you have to improve the input stage with LM319 and try feedback resister 22k instead of 47k.
regards,
Lycanlk
Old 14th August 2010, 07:19 PM   #337
Banned
It started no prollem with or without load but its unfortunately dead again, a loose strand on the +15V feed wire to the IR2010 touched a transistor leg with caused severe farting and banging from the speaker, then it was dead.
I now fear that pretty much every semiconductor on the board is dead so i figure its easier to just make a new board and start over.
Oh well **** happens i guess.
Btw my switching frequency was around 7µS which is around what, 50-100kHz ?
Old 14th August 2010, 07:50 PM   #338
81bas is offline 81bas  Germany
The problem with the startup in selfoscillating class d amp usually is that it MUST start with the negative impulse at the output, to let the bootstrap capacitor charge (I mean the bootstrap capacitor of the mosfet driver). If this condition is not met (if the comparator waits for INITIAL positive impulse at the output), then the bootstrap capacitor is not charged yet, and it is not possible to open the high side mosfet and it is not possible to generate any positive voltage at the amp output. So the amp simply will not start to oscillate...
To solve this problem, it is usually enough to connect amp output to the positive voltage rail using 50K-100K resistor. This will generate small positive voltage offset at the amp output after power is on, and the input comparator will initiate the negative cycle first, which will charge driver's bootstrap capacitor effectively...
Old 14th August 2010, 09:43 PM   #339
Banned
The amp is back from the dead!!
Old 14th August 2010, 10:58 PM   #340
Banned
Heres a scope shot of the carrier resudial:
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
