ucd 25 watts to 1200 watts using 2 mosfets - Page 338 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 30th March 2013, 06:34 PM   #3371
norazmi is offline norazmi  Malaysia
the core i already tested with amidoncorp and i`ve ordered 50 pcs T106-2, all good.
Old 31st March 2013, 10:26 PM   #3372
Banned
I was bored so i decided to revisit the UcD in this thread that i originally built about two years ago.
The circuit: http://i.imgur.com/zmhrLOm.png
The actual amp, i decided to split it into a modulator module and a power module: UcD type Class D amplifier - YouTube
Old 2nd April 2013, 02:51 PM   #3373
Banned
Anyone has a guess on how hot a 3A(source/sink) gate driver such as IR2010 or FAN7392 will get with 20 ohm gate resistor and mosfets with a total gate charge of 100nC at 400kHz ?
At 400ish kHz even with 30nC gate charge(IRF540) a IR2010 gets pretty hot.
Something tells me this will not even work at all.
These gate currents are scary!!
Old 2nd April 2013, 04:19 PM   #3374
andrewlebon's Avatar
Hi Tekko
greetings how accurate are LT SPICE stimulation results i have never used spice
need to stimulate a small d class amp input is TLO71 rest are trs
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 2nd April 2013, 04:34 PM   #3375
Banned
Well i got one power module together for testing:
Old 2nd April 2013, 05:17 PM   #3376
xrk971 is offline xrk971  United States
xrk971's Avatar
That's a darn small and compact 1200 watt class D amp if it works. Nice job! Is this the same circuit as in Post #13(around there)?
Old 2nd April 2013, 05:45 PM   #3377
CPX is offline CPX  Romania
@Tekko
Hot(>80 degrees) without active cooling.
With 100nC mosfets you must use a lower resistance(4 ohm) because rise time will increase to much(>150ns) and you will lose efficiency.
Old 2nd April 2013, 05:55 PM   #3378
Banned
Note that this is a power module only, no modulator. However i have tested it now and at first glance i can say the protoboard prototype sounded better.
Also i do need to lower the gate resistors as on 2x25VDC the heatsink is already getting warm, but 6 minutes near clipping did however not heat it excessively.
Old 2nd April 2013, 06:32 PM   #3379
Banned
So i halved the gate resistors by adding a second 22ohm on top of the existing one and now the amp is HOT.
IRFP150 is NOT a good dtransistor for class d!! Its quite the opposite, a clunky old piece of silicon, as soon as i get some better fets they'll be replaced.
Old 3rd April 2013, 07:22 AM   #3380
chago25 is offline chago25  Philippines
Originally Posted by andrewlebon View Post
Nice work sameer
can i have this files?
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
