ucd 25 watts to 1200 watts using 2 mosfets - Page 332 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 9th February 2013, 05:07 PM   #3311
akraj is offline akraj  Bangladesh
Originally Posted by andrewlebon View Post
Hi Akraj
greetings same design as posted in forum to make a proper d class amp FIRST get
a proper core then attempt to make a d class amp all yours problems will be solved
warm regards
andrew lebon
Hi Andrew:
Can I have appropriate core at Calcutta?
Raj
Old 9th February 2013, 09:15 PM   #3312
IRSound is offline IRSound  Germany
amp at 110 dc volts+/-
Hi ,
which FETs did you choose for this voltage ?
anyway , i just wondered how you can get good result with that smps (long wires to transformer ,....)
what is the benefits of toroidal core in this type of smps ?
_________________________________________
guys..
FDA69N25 have large Qrr which take effect on amp THD and efficiency.
what should we do then ?
Crown also using Fairchild FETs for XLS Drive core series.
Old 26th February 2013, 11:27 AM   #3313
adamkaktus's Avatar
Hi!
Is there any PCB, schematic and other files of IRS3000/1500 without errors in layout?I
I'm gonna build this amp, but i heard about some problems with resistors near tl071, unconnected capacitors and other problems. What Voltage rails should i use to achieve 3000 and 1500 Watts? Which part values vary depends on supply voltage? I have access to toroid cores -2 material, and other stuff, so i'd like to start with this amp.
Adam.
Old 1st March 2013, 10:18 AM   #3314
highand is offline highand  Hungary
Simple D class amplifier non smd part, without feedback.
http://www.hobbielektronika.hu/forum....php?id=191446
http://www.hobbielektronika.hu/forum....php?id=191441
Old 1st March 2013, 11:14 AM   #3315
More simple d class amplifier, without feedback.
Old 1st March 2013, 05:23 PM   #3316
Send a message via Yahoo to ionutzxpo
hi ,highand can you tell us some THD numbers? 0.0000X%? oscilating frecvency,can be made only with N chanel mosfets?
Iacob Ionut
Old 2nd March 2013, 07:34 PM   #3317
This circuit is TDH 0.1% high mark and TDH 0,3% low mark ( cross distortion). Possible to build only N-channel FET, such as Philips gate drive circuit.
Old 2nd March 2013, 08:18 PM   #3318
Old 2nd March 2013, 08:20 PM   #3319
This is the UcD version.
Old 3rd March 2013, 10:22 AM   #3320
Default Revised PCB for AUD600 Ver1.0
Any comment!
Corrected few missing tracks and on board BIAS regulator!
Credit goes to MANOJ!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 12:16 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
