ucd 25 watts to 1200 watts using 2 mosfets
Old 24th January 2013, 03:32 PM   #3281
luizcpimenta is offline luizcpimenta  Brazil
[QUOTE=Hadighorbani;3335818]
Originally Posted by luizcpimenta View Post
hi
i sent 2 pdf file in gmail for you
have nice time
Thanks.
Old 24th January 2013, 04:07 PM   #3282
Originally Posted by thienchay View Post
like this
Hi Thienchay.
The PCB IRS200D correct?
It worked perfectly?
I am needing to mount two of these plates.
Thank you for your attention.
Old 27th January 2013, 08:57 PM   #3283
IRSound is offline IRSound  Germany
Unhappy IRS-1500 Fail !
Hi guys..
so I've just finished IRS1500..but there is also a problem
please watch this video :
Class-D IRSD1K5 - No & Low Level input Problem - YouTube
when i turn on power supply..after s short delay , speaker connected to amp's out. as you can hear in video , there is a noise available at output. (input volume = 0) and when i increase volume up to 4~5%, a really bad audio signal become appear. also the active led indicator isn't bright constantly.
when i increase the volume (about 7~8 %) the amp start to oscillate and those problem solved.
guys please help me. anyone have similar problems ?
IRSound
Old 28th January 2013, 01:15 AM   #3284
jcoelhogsia is offline jcoelhogsia  Brazil
jcoelhogsia's Avatar
Originally Posted by IRSound View Post
Hi guys..
IRSound
post pcb picture in high definition to see what his mistake was.
Old 28th January 2013, 08:48 AM   #3285
Hi Jcoelhogsia,
Thanks for helping me..
this list shows the difference between my component and attached layout :
- Using BYV28-600 instead of MUR160 (beside IR2110)
- Using MUR460 instead of MUR160 after inductor
- Using 1N5819 instead of 4148 (mosfet's gate)
- Using IRFP250N instead of FDA69N25
- Using 47.5 Ohm gate resistor
and i have problem with no input signal and lower level input , like what you see in that video.
IRSound
Old 28th January 2013, 09:09 AM   #3286
Hadighorbani is offline Hadighorbani  Iran
i need help too for IRS1500D
Old 28th January 2013, 10:23 AM   #3287
Hi Jcoelhogsia,
IRSound
post the other side of the pcb.
Old 28th January 2013, 12:22 PM   #3288
ok...
do you have any suggestion ?
Old 28th January 2013, 05:11 PM   #3289
ok...
pcb ok, its assembly this perfect, as you have to replace the diode mur160, what voltage are you using? My run this perfect./http://www.youtube.com/watch?v=HU4e88xkp_M
Old 28th January 2013, 09:48 PM   #3290
Thanks ,
This MUR160 ?
supply voltage is about +/-55v
- also i replace those 6.8K with 5.6K.
Yes, i saw that video before. also video for 4K5 (what is the song in that video ?)
you don't have any problem in lower input signal at startup ? that blue led is light up at first ?
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
