| Class D Switching Power Amplifiers and Power D/A conversion |
#3271 |
#3272 |
Hi All, good night ... ^___^
detex-audio |
#3273 |
Hi IRSound
greetings TRY detex audio 2 pair amp with ocp post# 3219 FIRST PICTURE i used orignal cores which detex audio used 2 cores parallel 2 srx speakers on 2 ohm load NO ISSUES with amp heatwise and sound warm regards andrew lebon
[image] |
#3274 | |
You can send me the layout you are using the plates? Thank you. luizcpimenta@yahoo.com.br luizcpimenta@gmail.com |
#3275 |
Hi Andrewlebon ,
Thanks for guides.. yes , i should try it ! but can you tell me about output inductor ? what is the part number , manufacture and where the core originally from ? what is the value if you measured it with lcr meter ? did you use FDA69N25 ? Regards, IRSound |
#3276 |
#3277 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Also if they could climb the source information and the delay speakers(off delay) |
#3278 |
Hi irvinejay,
Why is 1n4148 not suitable? It has a trr of 4ns. Should the gate diode be a schottky type? Thanks
#3279 |
Trr 4ns but at 400mA current will heat. 1N5817/5819 has 1A will do just fine or MUR120 the best, low Trr and 1A (this is what i use in my comercial amps)
#3280 |
Thanks ionutzxpo,
But I think not all 1A is flowing into it because of the parallel resistor. |
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
