ucd 25 watts to 1200 watts using 2 mosfets - Page 327 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st January 2013, 01:13 PM   #3261
[QUOTE=pravpa;3335782]
Originally Posted by Hadighorbani View Post
Hi
thanks sir manoj for your best quality amp
Hello Hadi,
This Amp is nice and good, is it Aud600 by Manoj Sir??
Before going into this, I would like to make a budget, How much it costs you?
Pravin
Hi dear friend
this amp is best class D amp in diy steel
yes. this is AUD600
in iran we dont have good quality of part and every things we have is MADE IN CHINA
the price is about 15$ for me
Old 21st January 2013, 01:21 PM   #3262
[QUOTE=luizcpimenta;3335787]
Originally Posted by pravpa View Post
Hi
Its send me the files in this amp?
Thank you.
luizcpimenta@yahoo.com.br
luizcpimenta@gmail.com
hi
i sent 2 pdf file in gmail for you
have nice time
Old 21st January 2013, 01:30 PM   #3263
Originally Posted by irvynejay View Post
what part did smoke ?is your connection correct? input ground to main ground?
its weird
in this picture
bias gnd connected to -vss
about +vdd: can i connect the input pin lm7812 to +vdd and connect the out put pin lm7812 to + bias ?
what about gnd ? i mean can i connect the input lm7812 to gnd and out put pin lm7812 to +biass ?
thanks friends
Old 21st January 2013, 04:36 PM   #3264
hi hadi...
if you use below -+40v the green line connect to amp gnd,
Old 21st January 2013, 10:27 PM   #3265
irvynejay's Avatar
Send a message via Yahoo to irvynejay Send a message via Skype™ to irvynejay
Hello Hadi
I wonder why you get a lot of problem on this,,have you replace the defective ,,getting dc on output maybe you got problem or short on layout,commonly on tl071 tracks check voltage on 5.6v zener if they are balance,,bias is negative (Vss) reference
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 21st January 2013, 10:33 PM   #3266
Question sprint layout
Originally Posted by exflaco View Post
Hardi a working one
In part this file SPRINT LAYOUT, ​​that only found in PDF format.
Just came across this other Sprint Layout PCB, upload image I did find.
Old 22nd January 2013, 11:30 AM   #3267
Hi
this pcb had error
look at the blue mark
104 cap not connected to any vere
Old 22nd January 2013, 11:48 AM   #3268
savu is offline savu  Romania
savu's Avatar
Send a message via MSN to savu Send a message via Yahoo to savu
Connect it to the ground plane. (102 cap left to it).
no need to redesign
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Old 22nd January 2013, 01:27 PM   #3269
no need to redesign
thanks
Old 22nd January 2013, 01:53 PM   #3270
manojtm is offline manojtm  India
manojtm's Avatar
Hi Hadi,
Over current preset point connected to 104 this line should be connect to zener ZD5v6
MANOJ
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
