| Class D Switching Power Amplifiers and Power D/A conversion |
#3251 |
#3252 | |
![]() how can i know about cut in the out capasitor ? i was used T106-2 and wire 0.8 mm and 43turn i was used original lm317 board for 12 volts i was used another power source for 12 volt board and my negative amp power not conected to lm317 negative power and not common i dont conect my input gnd to out put or power gnd please show to me on a picture thanks |
#3253 |
Hadi the schm irs 3000 chek the same conections irs900 minus ocp and minus totempole
#3254 |
Hadi Chek post 3250 from Irvynejay its correct ,the same irs900 conections.
#3255 |
@Hadighorbani
you used 1n5819 in place of MUR120??? if so replace 1n5819 to mur120,,, irs900 freq is 250khz output filter should be around 47uh
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend |
#3256 |
Pls see file
and input ground should be connected to main ground
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend Last edited by irvynejay; 21st January 2013 at 11:22 AM. |
#3257 |
#3258 | |
[QUOTE=pravpa;3335782]
Its send me the files in this amp? Thank you. luizcpimenta@yahoo.com.br luizcpimenta@gmail.com |
#3259 |
#3260 | |
i was try VER2.0 of IRS900D but it not worked when i connected in put ground to power ground the amp have above 10V DC in output without that i had 5V DC in output in ver 1 of this amp i had 5V dc in output too |
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
