| Class D Switching Power Amplifiers and Power D/A conversion |
#3231 |
Hadighorbani using Sprint Layout
#3232 |
Its free Sprint-Layout pcb file donwload and open ,nex print layer you desire
#3233 | |
Thanks Raj |
#3234 | |
You may see from the attached picture that the volume wiring is okay as per diagram. Still no sign of luck, finally given audio input to pin 1 (by passed tl072) now the sound good, no HF noise. I changed couple of IC's, same result. I would like to increase rail voltage, please let me know which part need to be changed and what is the threshold voltage limit of this design? Thanks Raj |
#3235 |
guys...
anyone have schematic of irs-1500d ? Regards |
#3236 |
Hi exflaco
i was creat and fix the parts for IRS900D i was used IRF640N with 1K ohm OSC resistor what is the value for IRF640n gate resistor ? i want to use T106-2 how much the value of out put filter ? thanks |
#3237 |
#3238 |
#3239 |
For the diyers friends.
These 3 class d amps IRS (900-1500-3000) the same topologie and schematics the 1500-3000 ad OCP (overcurrent protecttion) personally prefer irs1500 with biger vmos like 90n20 (90a200v) or better irfp4768(93a250v)and work fine 2ohms load. Depend the load and the +-vcc inductor coul use 22-50uh no problem. look the little secrets down the pcb ![]() A smd little 100nf decoupling and use pcb 3000 only one vmos per side. Other mistake its the 12v auxiliary better 1,5-2a (use two paralel 7812 or lm317) one 7812 work in irs900 only |
#3240 |
Hi Hadighorbani,
What diode are you using for the gates? 1n4148 is sufficient. Sorry I cannot share the layout yet for my all in one class D. Please understand. Regards, |
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
