ucd 25 watts to 1200 watts using 2 mosfets
Old 17th January 2013, 02:47 PM   #3221
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default higher power smps
small smps under construction trafos 2 heavy
"It's Better to try and fail than to never know and always wonder"
Old 17th January 2013, 07:55 PM   #3222
Hadighorbani is offline Hadighorbani  Iran
hi
no one can not hellp me for create IRS900 and IRS1500 ?!!!!!!!!!!!!!!
Old 17th January 2013, 10:29 PM   #3223
exflaco is offline exflaco  Armenia
Hadi IRS 900 its easy and work cheap material use a correct pcb and the out filter coul use
ei33 old pc with gap 1mm and the sound its very good start 45v and irf640 good choice
Old 17th January 2013, 11:32 PM   #3224
DSCN3793 - YouTube
Old 18th January 2013, 06:00 AM   #3225
Default thanks to exflaco
Hi
mey be my pcb was wrong
but i dont have another pcb file
do you have it ?
i have T106-2 and dont need EI33
i was used IRF250N and 1K ohm OSC resistor
in 45 volt my IRS900 generate smoke in filter capasitor
how much power with IRF640N can generat this amp ?
Old 18th January 2013, 09:28 AM   #3226
luizcpimenta is offline luizcpimenta  Brazil
Originally Posted by jlester87 View Post
My new layout for 1KW Class D with onboard OCP and onboard bias supply.
2 Pairs IRFB4227 TO-220
Good day.
Could you send me the files of this amplifier?
Thank you.
luizcpimenta@gmail.com
luizcpimenta@yahoo.com.br
Old 18th January 2013, 11:05 AM   #3227
Hardi a working one
Old 18th January 2013, 11:18 AM   #3228
Hardi a working one
hi
thanks my friend
which one is OSC resistor in IRS900 ?
do you have any thing for IRS1500
shematic
pcb
layout
any thing
very thanks
Old 18th January 2013, 05:41 PM   #3229
Default irs1500
oscilattor resistor 1k
Old 19th January 2013, 04:49 AM   #3230
i can not use .LAY files but very thanks for your helping dear friend
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
