ucd 25 watts to 1200 watts using 2 mosfets - Page 322 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 13th January 2013, 11:49 AM   #3211
manojtm is offline manojtm  India
manojtm's Avatar
How many turns for emi reduction coil?
Hi Raj,
for first setup do not use EMI reduction winding.after everything working perfectly then use. it should be 10 Turns
MANOJ
Old 13th January 2013, 11:50 AM   #3212
manojtm's Avatar
Hi Raj,
check my connection picture again for VOLUME control wiring
MANOJ
Old 13th January 2013, 09:48 PM   #3213
Originally Posted by thienchay View Post
My New PCB , IRS-2000D , will be IRS-3000D if used +/-130V .
Good evening.
This pcb is correct?
I'm intending to build this amp.
You have to send me the files?
Thank you.
luizcpimenta@yahoo.com.br
luizcpimenta@gmail.com
Old 14th January 2013, 06:49 AM   #3214
Can i use Irf640 for testing?
Old 15th January 2013, 02:02 AM   #3215
Originally Posted by jlester87 View Post
My new layout for 1KW Class D with onboard OCP and onboard bias supply.
2 Pairs IRFB4227 TO-220
Hi jlester
did you test your pcb ?
is that worked ?
can you send to me yor pcb file please ?
thanks
Old 15th January 2013, 03:37 PM   #3216
akraj is offline akraj  Bangladesh
Originally Posted by manojtm View Post
Hi Raj,
VOLUME control(100K or 50K) side pin connected to 33K resistor from Pin-7 of TL072, center pin from Pin-2 of TL072 and another side from Pin-1 of TL072.
MANOJ
Hi Manoj: I think my wiring is as per your diagram/instruction. Attacing a picture for better understanding, is it okay.
Raj
Old 15th January 2013, 04:00 PM   #3217
Good afternoon.
This layout worked OK?
Its send me the files?
luizcpimenta@gmail.com.
Thankful.
Old 16th January 2013, 03:45 AM   #3218
stewin is offline stewin  Kenya
Hi Raj,
MANOJ
the 10turns should be winded on what type of material?
Old 17th January 2013, 01:10 PM   #3219
andrewlebon's Avatar
Default d class with smps
Hello
greetings small 2kw smps test on dclass
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 17th January 2013, 02:28 PM   #3220
Default smps test with dclass 2KW
Still to test on 120 volts dc +/- sameerx1
warm regards
andrew lebon
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 84 15th April 2016 02:02 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
